Help with Optic/Wave Question - Prove Entry Ray Exits Parallel
  • Thread starter Thread starter Arowana
Arowana
hi, i know that the entry ray of light into a medium will exits parrallel to the entry ray. The problem ask me to prove it. i have drawn a diagram and done the mathematical calculation. i just can't put it into words, could some one please help me out.
and 2nd part to that question is
Derive an expression for the offset of the entry and exiting rays if the
thickness of the sheet is T and the ray enters at an angle of incidence of θ.
aaaaaahhh...im so stress out..because of this simple question.
Perhaps, if you could show the mathematical calculation. Will your tutor not accept a proof based on calculations?
For you second part, simply use trig...
~H
thanks hootenanny
umm...i still don't get the 2nd part, how do i use trig?
Try drawing a diagram and making right triangles with the rays of light as the hypotenues.
~H
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
