Help with physics of my Magnet Motor
The discussion centers on a proposed magnet motor concept that mimics a pendulum's motion by utilizing magnetic forces for propulsion. The design involves four key components: Weight Magnet (W), Rebound Magnet (R), Electro Magnet (E), and Body (B), with dynamic forces acting on them. The creator seeks assistance in accurately mapping the simulation mathematically, particularly regarding the N-body problem of continuously applied magnetic forces. The hypothesis suggests that if forces equalize over time rather than instantly, it could generate thrust. The inquiry emphasizes the need for mathematical guidance to evaluate potential thrust from this innovative design.
JoeOfTex
The Idea
The idea is similar to a pendulum in motion. I noticed that it was possible to shift the weight towards a single direction causing an immediate force, which equalized over time. I figured I could use magnets to simulate a pendulum and also reset to the starting state using both magnetic attraction and repulsion.
Here is the concept: http://imgur.com/pK3UHhj
The Math Problem
There are 4 objects that have dynamic forces being applied. We'll call the objects Weight Magnet (W), Rebound Magnet (R), Electro Magnet (E), and Body (B). The Rebound and Electro are welded to the Body, so any forces must act on the combined mass of the three objects. The W and R magnets are static in strength, and the (E)lectromagnet can be scaled to any strength.
Here are all the variables:
  • Mass - W, R, E, B
  • Static Magnet Strength - W, R
  • Electromagnet Strength - E
  • Distance between - W and R, W and E
  • Oscillation Frequency - E
  • Time - W
  • Force - W, R, E, B
The pseudo simulation with looping Time period [1,9]:
  • Time(1) -- E repels W, outward force applied to E and W
  • Time(2) -- W force at 90%
  • Time(3) -- W force at 50%
  • Time(4) -- W force at 10%
  • Time(5) -- R repels W, outward force applied to R and W
  • Time(7) -- W force at 80%
  • Time(8) -- E attracts W, inward force applied to E and W
  • Time(9) -- W at distance=0 with E
I would really like to map out the simulation with math more accurately, and am quite unsure where to begin. What confuses me is the N-body problem of magnetic forces being applied at all times at dynamic distances. Any help with the math would be appreciated, thanks!
Electromagnetic vibrators are already common components in cellular telephones and adult toys for women. What is the point of this device?
Propulsion. The hypothesis is that if the motor equalizes forces over time instead of instantly, it can provide thrust.
The concept came from this pendulum motor:
Here is a figure of the forces: http://i.imgur.com/YTa0ST8.jpg
At t=1, C will repel B towards A.
At t=5, A will repel B back to C.
At t=7, C will attract B
I'm not a physicist, so I need help in figuring out the math to evaluate if there is the slightest thrust in any direction.
Thread closed for Moderation...
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
