Help with prototype, hooking up sensors and a pump to a circuit?
The discussion revolves around building a prototype that integrates two hygrometers and an air pump, focusing on the technical aspects of connecting these components to a microcontroller for humidity monitoring and control. The scope includes practical implementation and programming considerations.
  • Homework-related
  • Calvin outlines the need for a system that activates an air pump based on humidity discrepancies detected by two hygrometers.
  • One participant suggests using an Arduino board as a microcontroller due to its ease of use and supportive community.
  • A later reply provides a link to sample code for interfacing humidity sensors with the Arduino, which could assist in the programming aspect of the project.
Participants generally agree on the use of an Arduino board for the project, but there is no discussion of alternative approaches or components, leaving the conversation focused on this single solution.
The discussion does not address potential limitations of the proposed solution, such as the specific wiring requirements, power supply considerations, or the programming challenges that may arise.
Individuals interested in DIY electronics, hobbyist programmers, or those looking to integrate sensors with microcontrollers for environmental monitoring projects.
Calvin55
Hello,
I'm working on an invention in which I'm trying to build a prototype for. I have very little physics background and nothing in computers which is why I've sought help here. The project seems very basic, but I have no idea where to start.
I need help hooking up two hygrometers (digital humidity sensors) and an air pump together to some sort of simple computer. The goal is to get the air pump turned on for five minutes when the there is a discrepancy of 5% or more humidity from one sensor to the other. That's it. So say the inside is at 45% relative humidity and the outside is is at 30%. I would want the pump to turn on for the allotted amount of time and then off again for a while until there is another humidity discrepency. So I guess I need some sort of board or computer type thing to hook all these things to.
I'm building this prototype by buying $15 hygrometers and a $30 dollar air pump. I'm also thinking maybe I need a timer which plugs into the wall and to the air pump. Maybe the timer will be easier to hook up to the central board? I'd like it to be as cost effective and simple to put together as possible. I have no idea where to begin. I hope this post was clear and any help would be much appreciated.
Thanks,
Calvin
I think the best way to implement this in an easy and cost effective way is to go with an Arduino board ($30) for your microcontroller. http://www.arduino.cc/
It's very easy to use, programming it is a snap and the community is very large if you need some help.
wow, looks like what I needed. I'm going to dive right in and see how this works. Thanks!
Man, you are like GOLD! Thanks a lot man! Really appreciate the help.
  • · Replies 20 ·
  • · Replies 37 ·
