Help with proving this Kepler's laws based theorem
  • Thread starter Thread starter Dvsdvs
    Laws Theorem
The discussion centers on proving that if the magnitude of the radius vector r(t) is constant, then r(t) is perpendicular to its derivative dr/dt at all times. Participants clarify that this scenario implies a circular motion, where the radius vector is always orthogonal to the velocity vector. The mathematical proof involves showing that the derivative of r squared is zero, indicating that the dot product of r and dr/dt is also zero. This confirms the orthogonality of the radius vector and the velocity vector. The conversation concludes with a consensus that the proof is simpler than initially thought, with multiple approaches being valid.
Dvsdvs
the proposition is that if r(t) has a constant length (//r(t)// is constant), then prove that r(t) is perpendicular to dr/dt at all t.
I was thinking that if r(t) is just a function of the radius and its magnitude //r// is constant, then its basically talking about a circle? and by saying prove that r is perpendicular to dr/dt is basically asking to prove that the radius vector is always orthogonal to the velocity v(t) vector? I need a mathematical proof of this proposition using vectors. Thank, you
What is d/dt(r.r)?
BTW Kepler hasn't got much to do with it.
Any wiggly path on the surface of a sphere has constant r.
David
I'm not sure what your asking. this is a general proof so i don't know what d/dt(r.r) is. all the information i have is posted.
i got an idea... would the //x(t)// be equal to the length of the curve of x(t) and therefore //x(t)//=integral(x(t).dx/dt) and since //x(t)// is constant the indefinite integral can only=c if the x(t).dx/dt=0 and so they are perpendicular. Can someone please tell me if all this makes sense?
r^2 is constant:
0 = d/dt r^2 = 2 r dot dr/dt
oh ok so you're saying that since //r(t)// is constant then //r(t)//^2 is constant which means (r.r) is constant and that derivative which is a dot product is 0. yeah this was easier than i thought my integral solution also works i think
