Calculating Energy Delivered by a Pacemaker
  • Thread starter Thread starter Sloan650
The discussion focuses on calculating the energy delivered by a pacemaker to the heart, using a resistance of 100 ohms, a pulse amplitude of 1.2 volts, and a pulse duration of 0.5 ms at a stimulation rate of 70 bpm. The initial calculation yields an energy delivery of 7.2 microjoules per pulse, leading to an average power output of 8.4 microwatts. There is confusion regarding the significance of the current drain of 2 microamps, which is clarified as related to battery consumption rather than affecting energy delivery calculations. The calculations confirm that the power formula used incorporates current, aligning with the values provided in the exam question. Overall, the discussion emphasizes the importance of distinguishing between energy delivered to the heart and current drain for battery life considerations.
Sloan650
A pacemaker stimulates heart tissue with R of 100ohms.
Pulse amplitude is 1.2 Volts & pulse duration is 0.5ms.
Stimulates at 70bpm
Current drain = 2microamps
Calculate energy delivered to heart from pacemaker at each pulse.
i got
P=V^2/R = 0.0144
Then Energy = Power*time = 0.0144*0.5x10-3 = 7.2x10-6 J
But do i not need to take into account the current drain?
power P = V X I
and since I = V/R,
then
P= V X (V/R) = V^2/R
so when you did V^2/R you included current.
the 2 microamps sounds more like battery drain to me.
7.2 microjoules 70 times a minute = 8.4 microwatts
at 2 microamps dictates least 4.2 volt battery?
anything corroborate here?
2µA - It is current drain due to the pacemaker circuitry.
Im a bit confused, its a past exam question.
all the values i gave were all that was given in the question.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
