Help with Science calculations please
The discussion revolves around calculating the heat released when 500g of water vapor condenses, using a latent heat of condensation of 600 cal/g, resulting in a total of 300,000 calories released. Participants clarify that this energy will heat the surrounding air, which has a mass of 100kg. The specific heat of dry air at sea level is given as 0.24 cal/(g x °C), prompting a calculation to determine how much the air temperature will increase. The concept of heat balance is introduced, emphasizing the need to understand how energy transfer affects temperature change. Overall, the focus is on applying the correct formulas to solve the problem effectively.
glori1988
Suppose that 500g of water vapor condense to make a cloud about the size of an average room. If we assume that the latent heat of condensation is 600cal/g, how much heat would be released to the air?
If the total mass of air before condensation is 100kg, how much warmer would the air be after condensation? Assume that the air is not undergoing any pressure changes, and use the specific heat of dry air at sea level 0.24 cal/(g x oC).
I don't really know the formula to calculate
I times 500*600=300,000
That looks alright. 300,000 calories.
0.24 cal of energy heats 1 g of gas by 1 deg. How much will 300,000 cal heat 100 kg of gas?
I don't get your question.
Do you know what heat balance is?
