Solving PDEs with IC, BCs: Help from Kevin
  • Thread starter Thread starter jimmygriffey
    Pde
jimmygriffey
Hi:
I have the following PDE:
ytzz=yzzzz+delta(t)
With I.C.: t=0, y=0; and B.C.s: z=0, y=0,yzz=0; z=-x,y=0,yz=0
Can someone show me how to solve it?
Kevin
Yes, it is δ(t). The one is very similar to the previous one. After taking Laplace transform in t, this one will become the previous one. If I use the method pointed by other people, I have hard time to convert back (inverse Laplace transform) to time domain. That's why I ask the question again.
Kevin
Kevin
Yes - if one uses the Laplace Transform (which takes an equation from time domain to frequncy domain) then I believe it is the same problem. I'm expecting the problem is separable, i.e. Y(z,t) = Z(z)T(t). See if that works.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
