Help with solving this differential equation?
lillybeans
(3y4-11x2y2-28x4)dx-(4xy3)dy=0
My=Nx if equation is exact, if not, I can make it exact (I hope) by finding an integrating factor. The problem is I can't get the integrating factor to be a function of x or y only.
Let stuff in front of dx=M
Let stuff in front of dy=N
My=12y3-22x2y
Nx=-4y3
My-Nx=16y3-22x2y
First try (My-Nx)/N=(16y3-22x2y)/4xy3
Not a function of x only.
Then (My-Nx)/-M=16y3-22x2y/-(3y4-11x2y2)
Not a function of y only.
Am I using the wrong method to solve this question? I don't see any other way to go about it rather than turning this into an exact equation. Why can't I find an integrating factor that has a pure x or y expression?
Thanks.
M(x,y) and N(x,y) are both homogeneous of degree 4. So y = ux will make a separable equation of it.
Sorry, I haven't quite learned that yet. Do you mind elaborating a little? Is that another technique for solving differential equations? Something called substitution, maybe?
Thank you
A function ##f(x,y)## is homogeneous of degree ##n## if ##f(\lambda x,\lambda y)
=\lambda^nf(x,y)##. What ##n## works for your ##M## and ##N##?
Try the substitution ##y = ux,\quad dy =xdu + udx##.
[Edit, added later]: I see I forgot to tell what this type of DE is called. If is called a first order homogeneous equation. Unfortunately, this is not the same meaning of the term as when applied to a linear DE with 0 on the right side, where we refer to homogeneous vs. non-homogeneous equations. In the setting of your problem, it refers to the ##M## and ##N## being homogeneous in the above sense.
[solved]
Nevermind I made a mistake, that's why I thought I couldn't turn the last one into an exact one.
Thank you once again! :)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
