Help with understanding electromagnetic induction
6 replies · 3K views
coreluccio
When a charge is in motion, it produces a magnetic field. If the charge is in an external magnetic field, a magnetic force is induced on the charge. This I understand.
When a conductor is moving relative to a magnetic field, there is an induced current in the conductor. This I don't get. If the conductor is stationary, and the magnet is moved around it, then how is there a magnetic force exerted on the electrons in the conductor to induce a current? Wouldn't the conductor need its own magnetic field for a magnetic force to be exerted on it, and for it to have a magnetic field wouldn't it have to be in motion?
Thanks in advance.
It doesn't have to be magnetic force to induce current. If the magnet is moved, the field it creates is no longer a static magnetic field; it's electromagnetic field instead. The E-component of the field exerts forces on the electrons of the conductor.
coreluccio said:
I don't get it.
Where do you not get it?
The entirety of what you said.
Take a look at the illustration of an aviation ignition magneto on page 3 of this article by Will Fox:
http://eaa691.org/files/Tech%20Note%20%232%20Magnetos.pdf
The rotating 4-pole magnet induces an alternating magnetic field in the iron core, which generates a voltage and current in the coil (primary = 180 turns). This is a battery-less ignition system, where the power is generated by the rotating permanent magnet. This works on the Faraday law of induction.
Bob S
