csgirl504
- 18
This is my assignment: (Sorry, it's a little long)
You are required to write a UserID Java class to be used when generating and storing the user id and password for a new user of a system. At a minimum, each UserID object should store a first name, last name, user id, and password for a user. Your class should have no public instance variables and should provide the following public methods:
UserID
(String first, String last)
Constructor to create a new UserID object, initialize the first and last
names, and generate a user id and a password, using the rules specified in
programming assignment 2.
______________________________________________________________
UserID ( ) Constructor to create a new anonymous UserID object. The first name
should be initialized to “User” and the last name to “Anonymous”. The user
id and password should be generated as specified in programming
assignment 2, except that the number which is part of the user id should be
a random integer in the range 10-99 (instead of the sum of the lengths of
the first and last names).
_______________________________________________________________
getID ( ) Accessor that returns the user id as a String object. The same user id
should be returned each time this method is invoked for an object.
getName ( ) Accessor to return a single String containing the name with format “LAST,
FIRST” (all uppercase) _______________________________________________________________
getPassword ( ) Accessor to return (but not modify) the currently stored password.
setPassword
(String newPassword)
Void method to modify the stored password with the String passed as
argument. _______________________________________________________________generatePassword ( ) Void method that generates and stores a new random password that
follows the same format as the original password.
toString ( ) Returns a String containing the user’s last name, first name, user id, and
password.
This is my program so far. I know that there is something wrong in the first two UserID methods. I was initially getting the program to work, but that was only when I initialized the private String first = ""; But I shouldn't have to do that, right? We just learned about classes, and I'm trying really hard to understand. Any help/explanation is appreciated!
Code:
import java.util.*;
public class UserID
private String userID;
private String password;
private String first;
private String last;
int num;
Random generator = new Random();
Scanner scan = new Scanner (System.in);
public UserID(String first, String last)
String firstName = first;
String lastName = last;
// For user ID
String lastFive; // First 5 letters of last name
String firstLetter; // First letter of first name
int totalCharacters; // Total number of characters in first and last
// For password
Random generator = new Random(); // Generates random digits
int num1, num2, num3, num4, num5; // 5 random digits
String secondLetter; // Second letter of last name
// GENERATES USER ID
// Gets first five letters of last name and changes letters to lowercase
lastFive = lastName.substring(0, 5);
lastFive = lastFive.toLowerCase();
// Gets first letter of first name and changes it to lowercase
firstLetter = firstName.substring(0,1);
firstLetter = firstLetter.toLowerCase();
// Gets number of characters in the first and last name
totalCharacters = firstName.length() + lastName.length();
// Creates user ID
userID = lastFive + firstLetter + totalCharacters;
// GENERATES PASSWORD
// Gets first letter of first name and changes it to uppercase
firstLetter = firstLetter.toUpperCase();
// Generates 5 random digits
num1 = generator.nextInt(10);
num2 = generator.nextInt(10);
num3 = generator.nextInt(10);
num4 = generator.nextInt(10);
num5 = generator.nextInt(10);
// Gets second letter of last name and changes it to uppercase
secondLetter = lastName.substring(1, 2);
secondLetter = secondLetter.toUpperCase();
// Creates password
password = firstLetter + num1 + num2 + num3 + num4 + num5 + secondLetter;
public UserID()
first = "User";
last = "Anonymous";
// For user ID
int random; // Random number between 10-99
// For password
lastFive = last.substring(0, 5);
firstLetter = first.substring(0,1);
// Generates random number
random = generator.nextInt(90) + 10;
// Creates user ID
userID = lastFive + firstLetter + random;
secondLetter = last.substring(1, 2);
// Creates password
public String getID()
return userID;
public String getName()
return (first.toUpperCase() + "," + last.toUpperCase());
public String getPassword()
return password;
public void setPassword (String newPassword)
password = newPassword;
public void generatePassword()
password = first.substring(0,1) + num + last.substring(1,2);
public String toString()
return ("Last Name: " + last + " First Name: " + first + " User ID: " + userID + " Password: " + password);
Code:
import java.util.Scanner;
* This program can be used to test the UserID class methods.
* @author Dr.C.
public class UserIDTest
public static void main(String[] args)
UserID myInfo = new UserID("John", "Lennon");
System.out.println(myInfo.getID());
System.out.println(myInfo.getName());
System.out.println(myInfo.getPassword());
System.out.println(myInfo);
UserID unknown = new UserID();
System.out.println(unknown.getID());
System.out.println(unknown.getName());
System.out.println(unknown.getPassword());
System.out.println(unknown);
myInfo.setPassword("Imagine!");
unknown.generatePassword();
Exception in thread "main" java.lang.NullPointerException
at UserID.getName(UserID.java:132)
at UserIDTest.main(UserIDTest.java:16
