Help: (x-3) is a factor of x^2-4x+c, find c?
  • Thread starter Thread starter nukeman
To determine the value of c in the polynomial x^2 - 4x + c, given that (x-3) is a factor, one can apply the factor theorem, which states that if (x-a) is a factor, then f(a) = 0. By substituting x = 3 into the polynomial, the equation becomes 9 - 12 + c = 0, leading to c = 3. Some participants also discussed the importance of verifying the factorization by checking if the calculated c value satisfies the polynomial. Additionally, there were requests for similar examples to reinforce understanding of the concept. The final conclusion is that c must equal 3 for (x-3) to be a factor of the polynomial.
nukeman
If (x-3) is a factor of: x^2 - 4x + c, what is c?
I am really stuck here. When presented with these types of questions, what is the FIRST thing you look at/do ?
Thanks so much.
Thanks so much.
There's a theorem that deals with this. If x - a is a factor of a polynomial f(x), then f(a) = 0.
Here's an example:
f(x) = x3 - x2 - 5x - 3
As it happens, f(x) can be factored into (x - 3)(x2 + 2x + 1).
This means that x - 3 is a factor of f(x). It also means that f(3) = 0. We can verify this by calculating f(3) = 33 - 32 - 5(3) - 3 = 27 - 9 - 15 - 3 = 0.
Thanks so much.
The first thing I ask, is what do you know about polynomials and factoring.
For this problem, "What is the remainder of (x2 - 4x + c)÷(x-3), if (x-3) is a factor of x2 - 4x + c ?"
Holy crap, think I got it. Please let me know if correct?
(3)^2 - 4(3) + c
9 - 16 + c = 0
c = 7
? is that correct?
If (x-3) is a factor of: x^2 - 4x + c, what is c?(3)^2 - 4(3) + c
9 - 16 + c = 0
c = 7
? is that correct?
Do you really have to ask that? Is x-3 a factor of ##x^2-4x+7##? If it is you are done, otherwise you might want to check your arithmetic.
(3)^2 - 4(3) + c
9 - 16 + c = 0
c = 7
? is that correct?
What is 4(3) ?
(It's not 16.)
Oh, I wrote on my paper 4(4)
So correct answer is:
c = +3
Umm... sorry if this is a dumb question, but the last 2 I did, C is always the same as what they are telling is a factor of.
So, this one I just did, they say (x+3) is a factor of... would c automatically be +3?
The answer turned out to be +3.
Can someone give me another simular example to try?
c = +3
Can someone give me another similar example to try?
Work some examples out for yourself.
What is (x-3)(x+4) ?
The one you were solving in this thread has a factor of (x-3).
But, suppose the question is:
If (x+3) is a factor of: x2 - 4x + c, what is c?
If f(x) = x2 - 4x + c, what is f(-3) ?​
Hi sammy.
Ok, so for the question you gave me: If (x+3) is a factor of: x2 - 4x + c, what is c?
c would = -21 ?
nukeman said:
Hi sammy.
c would = -21 ?
Yes.
nukeman said:
Hi sammy.
c would = -21 ?
Nukeman, I will suggest again, when you have a problem like that and you think c = -21 so your function is ##x^2-4x-21##, why don't you just try factoring it yourself and see if x+3 is a factor instead of asking us if -21 is correct?
