Here I made a very simple motor
  • Thread starter Thread starter The legend
    Motor
A user shared a simple motor they created based on a science experiment book but sought clarification on its functionality. Another participant suggested using an iron core for the coil to enhance the magnetic field and improve performance, along with constructing better brushes for stability. The mechanics of the motor were explained, highlighting that electric current in a wire generates motion in a magnetic field, producing torque. The discussion also addressed how to create an iron core by wrapping wire around iron objects. The user expressed gratitude and indicated they would try the suggestions.
The legend
Look ... here I made a very simple motor ...(many of you guys might have made a more developed version though and could help me by showing your models too ...) which I saw from a science experiment book.
[PLAIN]http://img825.imageshack.us/img825/139/expt.png
But the thing is the book doesn't say how it works or why!
So could anyone please tell me the same?
And also I have seen DC motors... how come they are that small but more fast?(What is inside them??)
[PLAIN]http://img230.imageshack.us/img230/714/coolstorybro.gif
lol.
For your next motor, try an iron core for the coil. It improves the magnetic field inside the loops and you get more kick from your motor. Also construct better brushes because the coil will be heavier and can't stand on just the wires.
Good job mate, best of luck!
P.S. Now I see you asked something at the bottom. The reason it works is because when a current exists in a wire, it is essentially electrical charges in motion. When a charge moves in a magnetic field it experiences a force. When you have them in a loop you get a torque. The reason you strip off half of the wire is to get switching on and off, otherwise you'd have an oscillating motor.
http://en.wikipedia.org/wiki/Lorentz_force
Umm... what is an iron core for the coil? Is it an iron coil ?
wrap your wire around a bolt or a piece of iron. If you can find iron coins (which i doubt) you can make a coin stack. Or find steel washers and stack them.
Ok will try it out!
Thanks!
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
