Hidden boxthe under the surface of earth is missing
  • Thread starter Thread starter shiva999
    Earth Surface
Burying a box underground may not result in its disappearance due to tectonic plate movement, as surface objects like trees and rocks move at the same rate and direction. Tectonic plates can shift up to 10 cm per year, potentially displacing buried objects by significant distances over centuries. However, for a box to be "lost," it would need to be buried very deep, potentially becoming entrained in magma. The consensus is that while tectonic movement is real, it does not lead to the loss of buried objects in the way initially suggested. Thus, the idea of a box disappearing due to plate tectonics lacks substantial support.
shiva999
i read that if you hide a box under the surface of Earth by covering it,then if try to recover it after some hundreds of years you won't find it as box adjusts to other place is it true? explain
I suspect this is talking about plate techtonics. And I was going to say that plates simply do not move fast enough. But then I found, at http://hypertextbook.com/facts/ZhenHuang.shtml, that plates can move as fast as 10 cm/year which, over, say, 500 years, would amount to 5000 cm= 50 m. Now, that certainly is enough that you could "lose" an object carried along with the plate.
At the same rate as your finger nails grow I have heard.
Where did you read that? We need to establish if it might be true before establishing why it might be true.
You would have to bury the box really deep, for the techtonic plate to move without the box. In fact the box would then float away with the magma.
The problem is that surface objects such as trees, rocks, houses, etc. will all be moving at the same rate and in the same direction so a box buried half way between a tree and a rock will still be half way between the tree and the rock, even if all 3 have moved 50 meters.
