HIGH o/p dual power amplifier ( HELP )
The discussion centers on using the BA5417 power amplifier for a portable speaker project connected to a discman. The left and right audio channels should be connected to pins 11 and 12, while the ground wire connects to pins 10 and 13. Current requirements can be estimated using Ohm's law, with a suggested total of 1.5 amps for an 8-ohm speaker setup, which should be manageable with 8 AA batteries. A capacitor is recommended for the supply pins to mitigate switching transients. The discman already has a volume control, which may eliminate the need for additional circuitry.
amanmahadeshwar
HIGH o/p dual power amplifier (! HELP !)
i have attached the cct diagram i found about this IC BA5417
it is a power amplifier
as one can see pins 11 & 12 are input but how exactly does on give this input
i plan to give input from my discman so there will be one ground wire and the two audio channels , where exactly do these three wires need to go
also how can i introduce volume control to the cct.
lastly the datasheet of the IC is at :
http://www.ortodoxism.ro/datasheets/rohm/ba5417.pdf
i just can't figure out what current will be needed i plan to supply 12 V (from 8 AA battery) but how much current??
Just for background this amplifier will give output to a speaker the whole project is for making a portable speker for my discman
PLEASE HELP :confused::rolleyes:
Bit of a find this, might get one myself.
The left and right channels go to pins 11 and 12 as you say. The third will connect to the grounds on 10 and 13.
Don't need to worry about current if you're staying within the voltages limits. Just connect straight to it. But also add a cap to the supply pins to protect it from switching transients.
In order to find the amount of current required you should use ohms law. Ohms law states that I (current) X Resistance (ohms) = Voltage. You know that you are going to be using 12 Volts. I assume that you are going to be using 4 ohm speakers. If you use two of them, that will be 8 ohms. Which equals 1.5 amps. There are other considerations also. If you were to be using purely resistive parts instead of speakers, which have an AC component and therefore an inductive reactance, 1.5 amps would be the case for the speakers only and not including the circuity. But the answer to your question of how much current is that unless you use large speakers, 8 AA batteries should be enough. As for your question of volume control, doesn't your discman have volume control?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
