High voltage electric field does not stop electric motor
The discussion revolves around the interaction between high voltage electric fields and the operation of a low voltage electric motor, specifically examining whether a strong electric field can stop current flow in a wire connected to a fan powered by a 12-volt battery. The scope includes experimental observations, electrostatic principles, and safety considerations in high voltage experiments.
  • One participant describes an experiment where a fan connected to a 12-volt battery continues to operate despite the introduction of a strong negative electric field from a high voltage source, questioning the expected behavior of electrons in the presence of this field.
  • Another participant references electrostatic principles, mentioning that electric fields inside conductors behave differently and that a common ground or two electrodes are necessary to establish an electric field.
  • A participant suggests that the electric field from the high voltage source does not penetrate the wire carrying the 12 volts, allowing electrons to flow inside the wire and keep the fan turning.
  • One response provides a technical clarification about the presence of a small electric field along the wire and the effect of external fields inducing surface charges that cancel the internal field.
  • A later reply raises concerns about the safety of conducting high voltage experiments and suggests sticking to low voltage supplies for safety reasons.
Participants express varying views on the effects of high voltage electric fields on current flow in a wire, with some agreeing on the principles of electrostatics while others question the experimental setup and safety. The discussion remains unresolved regarding the implications of the findings and the safety of the experimental approach.
Participants note the importance of grounding and the distinction between voltage and electric field strength. There are concerns about the safety of high voltage experimentation, suggesting a need for caution and further clarification on the experimental setup.
This discussion may be of interest to those exploring electrostatics, electric motor operation, and safety in high voltage experiments, as well as individuals conducting similar experiments or studying related concepts in physics.
scientist1234
I have made an attempt at understanding electric field and the effect they have on electrons by making the following test (see attached picture).
What I did was take a 12 volt battery and connect a fan of a psu with it so the fan starts to turn by the flow of electricity, of course. I then wondered what would happen if I introduced a strong negative electric field to the wire. In theory if the electric field of the high voltage source was large enough it would stop the electrons from flowing from the negative source of the battery to the positive battery because the negative high voltage (electric field) would repel the electrons and so stop the current flowing.
I build a simple cascade voltage multiplier and used a piece of wire from a neon sign supplier to protect the battery and wire from -10 kilovolts. The neon sign wire itself can hold 20 kV.
I placed the wire of the cascade voltage multiplier next to the thick insulation of the neon sign wire and so create an electric field between the high voltage source and the 12 volt wire without there being a current flow.
My assumption was the high voltage electric field would stop the current in the wire to the fan and so would stop the fan from turning. But instead the fan kept turning if nothing was wrong.
Could someone explain to me how it is possible to have current in a wire when the current would have to be repelled by the high voltage electric field.
Thanks
There is something in electrostatics about fields inside a conductor. Remember Faraday´s cage?
btw. - You need two electrodes or a common ground to have an electric field.
- Voltage and field strength are not the same.
Thanks for the reply
Ok so correct me if I am wrong but since the high voltage electric field stops at the outermost surface of the wire (carrying the 12 volts) and the electrons continue to flow on the inside of the wire because there is no electric field inside the 12 volt wire and so the fan is still able to turn.
In my tests I powered the cascade voltage multiplier with a variac, the cascade voltage multiplier itself has only 1 output wire or electrode (in my case negative high voltage, to repel electrons) and the other wire to complete a circuit would be ground. But in this case the second electrode is the 12 volt wire. So I assumed all voltages were relative to ground. Would it be correct to do this in this test or not.
You´re correct enough with your explanation.
Let me be very technical: Of course there is a (very small) electric field along the wire, otherwise there would be no current. (Electrostatics does not consider currents). An external field induces surface charges (a distribution of the existing charges) on a conductor, which cancel the field inside.
As far as I see from your sketch, your 12V battery circuit is isolated from the HV supply, and you better leave it so. I don´t want to be impolite: the questions you ask make me doubt if you can handle high voltage safely. Maybe you continue your experiments with batteries and low voltage DC supplies; this way, if you make a mistake, the damage will be to (hopefully cheap) components, but not to yourself.
thank you that explains it
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 16 ·
