High voltage voltage controlled linear variable resistor
High voltage analog circuits (300V+) require a voltage-controlled linear resistor for digital control, with LDR optocouplers being unsuitable due to voltage limitations. Transistor or diode optocouplers are suggested alternatives, with photodiodes acting as light-controlled zeners and phototransistors as light-controlled transistors. The discussion highlights that multiple LDR optocouplers can be used in series to achieve higher output voltages, provided LED currents are matched. A proposed solution involves creating a current source where the LDR only needs to handle a small voltage to bias a FET, allowing it to manage the higher voltage. The conversation emphasizes the importance of ensuring the isolation voltage is sufficient for safe operation at 300V.
coinmaster
I have some high voltage (300v+) analog circuits that I want to control digitally which requires the use of a voltage controlled linear resistor that can withstand high voltages. I don't expect the current levels to be that high.
I originally settled on LDR optocouplers but it turns out they can't handle big voltages so that leaves me with transistor or diode optocouplers.
As far as I understand it, photodiodes are light controlled zeners and phototransistors are light controlled transistors.
Which one should I choose for a high voltage linear variable resistor meant for a voltage divider?
If you put multiple LDR optocouplers in series you would be able to get an arbitrarily high output voltage. You will just need to make sure your LED currents are closely matched. 300V should not be a problem as long as the isolation voltage of the part is high enough.
BoB
might this help ?
Make a current source...
LDR only has to handle the few volts necessary to bias the FET, FET takes the rest. Voltage across LDR is small compared to 300.
apparent resistance = 300V/current
http://users.ece.gatech.edu/mleach/ece3050/notes/ISources/isources.pdf
see also http://www.vishay.com/docs/70596/70596.pdf
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
9K
