Building a Budget-Friendly Linux Cluster: Tips and Tricks from Hak5
  • Thread starter Thread starter Gunthi
    Home Linux
Creating a computing cluster using old computers can be an engaging project, particularly for distributed computing tasks. Beowulf clusters are a popular choice, and while specific tutorials may be scarce, there are resources available that provide guidance on hardware and software setup. A master node is essential for managing the cluster, typically running a Linux distribution like Red Hat or Ubuntu Server Edition, which offers accessible step-by-step guides. Key software components include setting up services like DHCP, SSH, and NTP, along with using MPI for parallel processing.For hardware, a reliable network switch is crucial, as cheaper models may struggle with high traffic. While SETI at Home can be run on a cluster, it does not support parallel computing, meaning each node would work on separate datasets. For those looking to minimize costs, using recycled components and basic setups can yield significant performance improvements. Additionally, various books and online resources can provide further insights into building and configuring a cluster effectively.
Gunthi
I have some old computers at home and I want to put them to work by making a cluster, maibe run SETI or other distributed computing related stuff.
I've searched the Internets, found out about Beowulf Clusters, but I can't seem to find any useful tutorial on how to make one.
So I'm calling out for some help.
1.Has anyone here made a cluster?
2.If so, what bibliography/references did you use?
3.What's the best Linux distribution for it?
4.What network hardware do i need?
Thanks in advance!
Computer science news on Phys.org
I have helped building a cluster, but mostly the hardware part.
Software-wise there was a master node on one server from which all other servers booted redhat over the network. The master node hosted an NTP server which synchronized time with slave servers, and also hosted a bunch of other server stuff like SSH, FTP, DHCP I think.
The software was running MPI implementation in C or C++, and LINPACK to do linear algebra. But how they configured it I have no idea. But it's definitely on my to do list.
Also the network switch that was used to connect up all the servers was expensive with really good response time. Cheap network switches are slow when it comes to switching lots of short and chatty bursts.
I don't intend to invest a lot of money in this, the pc's are all bellow pentium III so I'm not expecting to build a Deep Blue.
So, regarding the hardware, to connect all the nodes and server, a network switch will do right?
Also, do you know any good books about this?
Thanks ;)
Here is a mini guide on making a cluster
http://www.mini-itx.com/projects/cluster/
yes, any cheap 10/100 switch will do
Thanks for the link ;)
The hardware part is ok but it gets a little bit too advanced for me in the software part...
Do you know tutorials that are a little more accessible?
I haven't found any more in-depth guide on the net, but there are dozens of books on amazon. But I suppose they assume a more in-depth linux/unix knowledge.
If you are not familiar how to set up a DHCP, SSH, RSH, NFS, NTP, FTP, or Apache on linux it would be a good idea to learn those individually before attempting to actually building the cluster. I would recommend setting up ubuntu server edition on the computers since ubuntu has very good step by step guides.
Secondly, once you have the computers connected and talking to each other, google around on how to setup up MPI on them.
Thirdly, what would you like to run on it? SETI at home doesn't support parallel computing. You could set up SETI on the computers but they would be working on completely independent data sets.
Ok, I'll look into those.
I didn't know that. Thanks for the help and patience! ;)
I don't know how much it would help to reply to a year-old post, but I recently built a homemade Beowulf cluster using Debian Linux, DRBL, and the Sun Grid Engine (SGE). I've documented the hardware and software configurations http://sites.google.com/site/woojay/helmer" .
Recent example of building a small cluster without spending money on frills
http://revision3.com/hak5
episode 823.
To keep cost down, for example, he didn't buy cases but just used the cardboard boxes that the motherboards came in as the cases.
Sometimes the Hak5 episodes seem like they are just giving hints and perhaps keywords that you will have to go do some digging on your own, or perhaps send them a polite question or two, to figure out how to use that in your own situation.
I'd suggest buying a few Fry's loss leader motherboard/cpu combos that will provide perhaps 100x the performance of the PIII, get a few recycled old cases, power supplies and old low performance pci video cards, leave the sides off, aim cheap house fans at the boards to keep them cool.
