Homework in Solid state material
The discussion focuses on calculating the electric field near a depth of 500nm in silicon, where the electron concentration varies linearly from 5x1015 cm-3 at the surface (x=0) to 1015 cm-3 at x=500nm. The vertical electron current density is constant at Jn=100 A/cm2, and the mobility is given as 1250 cm2/Vs. The relevant equation for total electron current density is Jn = q Dn (dn/dx) + q μn E, where q is the charge of an electron (1.6E-19 C) and Dn is approximately 0.026 μn at room temperature.
  • Understanding of semiconductor physics, particularly silicon properties
  • Familiarity with electron mobility and current density concepts
  • Knowledge of the relationship between drift and diffusion currents
  • Basic proficiency in calculus for differentiation (dn/dx)
  • Study the derivation and application of the equation Jn = q Dn (dn/dx) + q μn E
  • Explore the concept of electron mobility in semiconductors and its temperature dependence
  • Learn about the diffusion coefficient Dn and its calculation in semiconductor materials
  • Investigate the effects of electric fields on charge carrier behavior in silicon
This discussion is beneficial for electrical engineers, semiconductor physicists, and students studying solid-state materials, particularly those interested in charge transport phenomena in silicon.
Blond Arrow
Here is the problem:
The electron concentration in a region of silicon depends linearly on depth with concentration of 5x10^15 cm^-3 at surface (x=0) and 10^15 cm^-3 at depth of x=500nm. If the vertical electron current density in this region is constant at Jn=100 A/cm^2, calculate the electric field near x=500nm. assume that the mobility is constant at 1250cm^2/Vs.
If anyone can at least explain the meaning of each value written in the problem and the formula that can be used to solve this problem ..
Thank you...
No one know?
The equation that you need is for the total electron current density (drift plus diffusion).
[tex]J_n = q D_n \frac{dn}{dx} + q \mu_n E[/tex]
q = 1.6E-19
D_n = (kT/q) u_n which is approx 0.026 u_n at room temperature.
Since you know J_n and dn/dx then E is the only unknown.
