Why Does the Constant 't' Appear in the Derivative of a Homogeneous Function?
The discussion centers on the appearance of the constant 't' in the derivative of a homogeneous function, specifically when differentiating the left-hand side of the equation ƒ(tx1, tx2, …, tn) with respect to x1. The use of the chain rule is highlighted, where the derivative of the function is multiplied by the derivative of the inner function, resulting in the factor 't'. Confusion arises from the notation used, which seems to imply differentiation with respect to x1 rather than the transformed variable tx1. Participants emphasize the importance of clear notation and understanding the chain rule to grasp the concept fully. The conversation also touches on the challenges of writing mathematical expressions neatly and efficiently.
Sidney
I've been reading a book on economics and they defined a homogeneous function as: ƒ(x1,x2,…,xn) such that
ƒ(tx1,tx2,…,txn)=tkƒ(x1,x2,…,xn) ..totally understandable.. they further explained that a direct result from this is that the partial derivative of such a function will be homogeneous to the degree k-1.They proved this by simply differentiating both sides of the equation. My problem arises when they differentiate the left hand side (with respect to the first argument as an arbitrary choice). They say the partial differential(of the LHS wrt x1) is:
(∂ƒ(tx1,tx2,…,txn)/∂x1).t
my question is where does the t come from.. ..please bear with me
Mathematics news on Phys.org
They used the chain rule. When you take a derivative of
f(g(x)) with respect to x, you first take the derivative of f, but then you need to multiply by the derivative of g.
\frac{d}{dx}f(g(x))=f'(g(x))\cdot g'(x)
So
\frac{d}{dx}f(tx)=f'(tx)\cdot \frac{d}{dx}tx = f'(tx)\cdot t
assuming t is independent of x (constant).
thank you :) I don't know why it seems so obvious now ..I did think of the t as being a result of the chain rule but for some reason the way they wrote it down made no sense to me and had me stuck...I think it's because they wrote (∂ƒ(tx1,tx2,…,txn)/∂x1) which to me means with respect to x( i.e. ∂x1) and not with respect to the change in the intermediate function(tx) and so it came across as meaning the complete derivative of ƒ1 encompassing all the intermediate processes..
the way you have your functions written down is so neat. If you don't mind me asking what did you use because the way I'm doing it takes forever, is very messy and I can't write in fraction form
Things often become clear again when it's explained in simple terms :)
Check out this page:
https://www.physicsforums.com/threads/introducing-latex-math-typesetting.8997/
And what you can also do to help speed up the learning process is to quote a post and observe what the poster had written in their latex.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
