Hooke's law from first principles
  • Thread starter Thread starter Acut
    Hooke's law Law
Hooke's law can be derived from first principles through an understanding of interatomic forces, specifically the balance between electrostatic attraction and Pauli repulsion. The energy around an equilibrium position can be expressed using a Taylor series, leading to the formulation of Hooke's law. While electrostatic models alone may not suffice due to limitations like Earnshaw's theorem, incorporating Pauli repulsion provides a viable explanation for atomic spacing in solids. Quantum mechanics explains Pauli repulsion, but classical mechanics can also account for nuclear electrostatic repulsion. Overall, the discussion highlights the interplay between quantum and classical models in understanding elasticity.
Acut
Following a discussion in this forum, I have a question: Is it possible to derive Hooke's law from first principles?
I think a purely electrostatic model is not adequate: Earnshaw theorem would imply there's no "relaxed" position. Also, electrostatic forces get weaker with increasing distance, the opposite trend of spring forces.
Is my reasoning correct? Have I overlooked something? Is it possible to create a purely electrostatic model of elasticity?
Absolutely. In solids, atoms sit at an energy minimum (specifically, electrostatic attraction balanced by Pauli repulsion) that governs interatomic spacing. The energy values E(x_0+\Delta x) around any minimum at x_0 can be expanded as a Taylor series,
E(x_0+\Delta x)=E(x_0)+\frac{\partial E(x_0)}{\partial x}\Delta x+\frac{1}{2}\frac{\partial^2 E(x_0)}{\partial x^2}(\Delta x)^2+\dots\approx \frac{1}{2}\frac{\partial E(x_0)}{\partial x}(\Delta x)^2
which is Hooke's Law where k=\partial^2 E(x_0)/\partial^2 x (taking E(x_0) as our energy reference and noting that \partial E(x_0)/\partial x is zero because we're at an energy minimum). Does this answer your question?
You Taylor series reminded me we may model spring forces with nearly any kind of forces - since Hooke's law is linear, many forces will fit it for suficiently small displacements.
So there's something that avoids the consequences of Earnshaw's theorem- Pauli Repulsion.
Is Pauli Repulsion explained with quantum mechanics? Or is there a way of modelling this repulsion using only classical mechanics?
Pauli repulsion is indeed explained with QM. And on the classical side, nuclear electrostatic repulsion may play a part too in controlling equilibrium atomic spacing, though I don't know offhand to what extent.
These effects are often modeled empirically with a repulsion term (e.g., in the http://en.wikipedia.org/wiki/Lennard-Jones_potential" ).
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
