How Aeroplanes Fly: Deriving Equation For Lift Force
  • Context: Undergrad
  • Thread starter Thread starter billy92
The discussion revolves around the derivation of the lift force equation for aeroplanes, specifically the equation \(\frac{1}{2}ρv^{2}AC_{L}\). Participants explore the theoretical underpinnings of lift, the significance of various terms in the equation, and the complexity of the coefficient of lift.
  • One participant seeks to derive the lift equation and expresses uncertainty about its formulation.
  • Another participant explains that the equation represents a proportional relationship between factors affecting lift, emphasizing the role of dynamic pressure and the coefficient of lift.
  • A different participant notes that the coefficient of lift (\(C_L\)) is a complex function influenced by multiple variables such as angle of attack and Reynolds number.
  • There is mention of alternative equations for lift, prompting questions about their relevance and derivation.
  • Participants discuss the use of polar charts to illustrate the relationship between \(C_L\) and various parameters, indicating the complexity of real-world applications.
Participants express varying levels of understanding regarding the derivation of the lift equation and the coefficient of lift. There is no consensus on which equation best describes lift, as multiple formulations are acknowledged.
Participants highlight the dependence of the coefficient of lift on several factors, including angle of attack and airfoil shape, which complicates the derivation and application of lift equations. The discussion also references the Reynolds number and its significance in aerodynamic analysis.
Individuals interested in aerodynamics, aircraft design, and the physics of flight may find this discussion relevant.
billy92
I am currently looking into how aeroplanes fly for a report which i am writing.
I understand the theory behind the lift force produced by different pressures above and below the wing. However, i need to use equations which i can show how to derive in the report.
I have found the following equation [itex]\frac{1}{2}ρv^{2}AC_{L}[/itex] but i am not sure how to derive this equation.
Thanks
If you understand the mechanism by which the aeroplanes fly, understanding this equation is not a very difficult task. First of all, you must realize that this equation only describes the proportional relationship between different factors affecting the lift.
As you pointed out, Lift is produced due to pressure difference on the upper and lower surface of the wing.
Lift (Force) = Aera X Pressure.
The term 1/2 ρ v^2 is the dynamic pressure, which can be thought of as the pressure (rather fall in pressure) due to movement of air over the wing (remember bernoolli's equation: P + 1/2 ρ v^2 = constant). Then you have the area (S) of the wing.
The last term, Cl is basically the proportionality constant which depends only on the shape and the cross-section (airfoil) of the wing. It basically depends on the way the wing redirects the flow to produce lift. So you will have the same Cl for a particular aircraft flying at different speeds or even if the aircraft is scaled down.
Thanks for the reply. I am fine with most of the theory behind it its just the derivations and formulas that I am a little stuck on.
Im still not entirely sure how to derive the equation i stated. Also is it this equaion which best describes lift as I've found others which also explain lift in slightly different ways.
It's not derived, it's a rearrangement of the equation used to define CL
[itex]C_L = \displaystyle \frac {L} {\frac{1}{2}ρv^{2}A}[/itex]
where L is lift force.
In the real world CL is a complex function of angle of attack, velocity, air parameters and wing parameters. Normally velocity, air parameters and the chord length of a wing are combined to create a term called Reynolds number:
http://en.wikipedia.org/wiki/Reynolds_number
2d charts called "polars" for airfoils will show one or more curves for CL versus angle of attack, Cd (coefficient of drag) versus angle of attack, and/or CL versus Cd, with separate curves based on Reynolds Number, like RE = 10^5, RE = 10^6, ...
http://www.davincitechnologies.com/AOTour5.htm
Programs used to generate these polar charts use some simplified version of Navier Stokes equations. XFOIL is a freeware version of this type of program:
http://web.mit.edu/drela/Public/web/xfoil
Thanks for the reply. Makes a bit more sense. Is the equation for the coefficient of lift derived from anything?
Also is there any other equations for lift which i should be looking in to?
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 124 ·
16K
  • · Replies 23 ·
