How are mass calculations done in the weightless environment of space?
  • Thread starter Thread starter nuby
    Mass Space
Mass calculations in a weightless environment, such as space, can be performed using methods like attaching an object to a spring with a known spring constant to utilize simple harmonic motion. This technique allows for the determination of mass based on the object's moment of inertia. The principle was effectively used to measure astronauts' mass on Skylab. While some may argue that only moment of inertia can be calculated, oscillating mass on a spring provides a practical solution. This method demonstrates how mass can still be measured accurately despite the absence of gravity.
nuby
Mass calculations in space
If an astronaut wanted to determine the mass of an object in outer space (0g), what is the procedure?
Astronomy news on Phys.org
Could you though? I would think you would only be able to calculate the moment of inertia, not the actual mass.
You could attach it to a spring with a known spring constant and use simple harmonic motion.
One could calculate the mass of a body of known geometry from it's moment of inertia.
However, I do think this would be the better option.
Oscillating the inertial mass on a spring was the principle used to measure the mass of astronauts on Skylab.
As I'm new here I can't post urls in my messages yet, but search for "Mass Measurements Aboard Space Station Skylab" with your favourite search engine and you should get a hit from the NASA website which describes the device used to measure the astronauts' mass.
Thanks... a few more posts and I'll have the power to give URLs.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
