How can a Helmholtz arrangement be used to null out magnetic fluctuations?
  • Thread starter Thread starter Brainy_Mike
    Helmholtz
The discussion focuses on utilizing a Helmholtz arrangement to nullify magnetic fluctuations caused by external magnetic fields. It is established that the correct current through the coils in a Helmholtz configuration can create a stable magnetic field, while an anti-Helmholtz arrangement is necessary for achieving a zero-field region. The conversation also highlights the application of this setup for stabilizing a neodymium magnet's interaction with the Earth's fluctuating magnetic field, emphasizing the importance of calculating the required current and magnetic field strength for effective implementation.
  • Understanding of Helmholtz coil configurations
  • Knowledge of magnetic field calculations
  • Familiarity with neodymium magnets and their properties
  • Basic principles of electromagnetism
  • Research how to calculate magnetic fields generated by Helmholtz coils
  • Learn about anti-Helmholtz arrangements and their applications
  • Explore methods for measuring magnetic field strength and current
  • Investigate the effects of Earth's magnetosphere on neodymium magnets
Researchers, physicists, and engineers interested in magnetic field manipulation, particularly those working with coil arrangements and magnetic stabilization techniques.
Brainy_Mike
hey I am pretty sure that if the right amount of current passes through the pair of coils in a helmholtz arrangement, the magnetic field it produces can null out any magnetic fluctuation. but how can you calculate the magnetic field it generates?
thanks a lot
and correct me if there was any inaccurate info above.
If you're talking about creating a zero-field region, what you need is coils in an anti-Helmhotlz arrangement, where the current in one coil flows in the opposite direction to the current in the other coil. Even then, the field will only be zero in a relatively small region between the coils. However, this arrangement also ensures that near the centre of the coils the first derivatives of the field also go to zero, which can be a good thing, depending on the application.
thanks, that's pretty helpful, ok this is what I am planning to do:
suspend a rare-earth magnet (small, very strong, neodymium) in a box and attach a small piece of mirror on the magnet, shine a beam of laser light on the mirror. supposedly if the magnets are strong enough, it can interact with the Earth's magnetosphere, which is constantly changing, therefore, the disturbances in the Earth's magnetic field can cause the neodymium to fluctuate. so in theory, if the helmholtz arrangement can generate enough magnetic force by pumping current through it, the magnetic field will null out the disturbances and fluctuations observed in the neodymium magnet. and now I am trying to figure how to set the device up and how to measure the amount of current & magnetic field needed.
any suggestion/help/advice is greatly appreciated!
thanks
