How Can Hermitian Operators Prove Key Quantum Mechanics Equations?
7 replies · 3K views
Raz91
Prove the equation
[itex]A\left|\psi\right\rangle = \left\langle A\right\rangle\left|\psi\right\rangle + \Delta A\left|\psi\bot\right\rangle[/itex]
where [itex]A[/itex] is a Hermitian operator and [itex]\left\langle\psi |\psi\bot\right\rangle = 0[/itex]
[itex]\left\langle A\right\rangle[/itex] = The expectation value of A.
[itex]\Delta A[/itex] = The standard deviation of A.
My attempt :
I tried to write [itex]\left|\psi\right\rangle[/itex] as a superposition of the eigenfuncion of the operator [itex]A[/itex] and used the fact that it's a Hermitian operator
[itex]A\left|\phi_{n}\right\rangle = \lambda_{n}\left|\phi_{n}\right\rangle[/itex] , [itex]\left|\psi\right\rangle = \sum a_{n}\left|\phi_{n}\right\rangle[/itex]
so that [itex]A\left|\psi\right\rangle = \sum a_{n}\lambda_{n}\left|\phi_{n}\right\rangle[/itex]
and [itex]\left\langle A\right\rangle = \sum |a_{n}|^{2}\lambda_{n}[/itex]
[itex]\Delta A = \sqrt{\left\langle A^{2}\right\rangle - \left\langle A\right\rangle ^{2}}[/itex]
and I wrote [itex]\left|\psi\bot\right\rangle[/itex] as [itex]\left|\psi\bot\right\rangle = \sum b_{n}\left|\phi_{n}\right\rangle[/itex]
[itex]\sum a^{*}_{n}b_{n} = 0[/itex]
I don't know how to go on from here...
any ideas?
thank you! :)
Hmm, using that the s-adj A has a purely discrete spectrum is not ok, it's not assumed in the problem. And I think you left out a square. I get
[tex]A\psi = \langle A \rangle \psi + (\Delta A)^2 \psi_{\perp}[/tex]
under the simplifying assumptions [itex]\psi_{\perp} \in D(A)[/itex] and [itex]\mbox{Ran}(A)\subset D(A)[/itex].
The first step I found to resolution is to calculate:
[tex]\langle \psi,(A-\langle A\rangle ) \psi\rangle[/tex]
What do you get and what do you conclude ?
I didn't miss the squar.. this is the question.
you get wrong units if you put the squar there ...
this yields zero .. i didn't understand how it can help me
thank you
I don't understand something -
there are lots of functions that can be perpendicular to psi
e.g (euclidean space)- the vector z (cartesian coordinates) , x is prep to z and y is prep to z but also the superposition (x+y) is prep to z.
so by writing psi prep do u mean to the superposition of all the functions that prep to psi or it's enough to choose only one?
Yes, Psi_perp is an arbitrary vector perpendicular to the psi already chosen. You get from ⟨ψ,(A−⟨A⟩)ψ⟩ = 0 that C psi_perp = A psi - <A> psi. All you need to show is that C is related to the standard deviation in square.
