How can I change voltage instead of current?
7 replies · 2K views · last reply
kolleamm
TL;DR
change voltage instead of current.
I have a micro controller that reads voltages from 0V to 5V
I did some tests on a potentiometer and I couldn't seem to get any readings of values in between. (range is 0-255 ,, 0 is for 0 volts and 255 is for 5V)
Therefore I'm assuming the voltage is staying the same as it turns but the current is changing.
How can I get the voltage to change instead of the current?
Thanks in advance
kolleamm said:
Summary: change voltage instead of current.
I have a controller that reads voltages from 0V to 5V
Thanks in advance
It's not clear what your setup is. This "controller" is a power supply or a meter? You say it "reads" but maybe you mean it produces?
My bad I meant a micro controller attached to a computer that reads input voltage values from it's pins.
OK, still very unclear
how about a schematic of your circuit, showing ALL component values
and what micro controller you are using
otherwise it is just a guessing game trying to figure out what you are trying to doDave
Reads input values from what? Is that device outputting a voltage or current signal? Typically you can change a voltage signal to a current signal by adding a resistor to the circuit...
The potentiometer has three terminals to solder to. It sounds like you connected to only two of these?
Hook it up like this. The "clockwise" (CW) potentiometer pin should connect to 5V, and the CCW pin should connect to ground. The wiper goes to your ADC input pin on the microcontroller (uC). R2 and C1 are optional, but will help to steady the readings you get.
https://www.w9xt.com/img_1224968365_15498_1331504476.png
245775
You were right, I had to attach all three to the board and that fixed it. Thanks all
