How can I find a solution for c and d for all real integer values?
  • Thread starter Thread starter x86
    Integer
x86
$$w = \frac{(ab - d) }{c - a - b}$$
I have to solve the above equation for variables `c` and `d` if `w` can be any number from $$w \in (-\infty, +\infty)$$
If we set `w = 0, then w = 1` we can solve for `c and d`
$$0 = ab - d$$
$$d = ab$$
$$c = a + b$$
Now if I can substitute the values to check the solution for `w = 1`
$$c - a - b = ab - d$$
Substituting c, $$a + b - a - b = ab - d$$
$$0 = ab - d$$
$$d = ab$$
I know that my solution is true for both `w = 0 and w = 1` but how can I prove that my solution is true for $$w \in (-\infty, +\infty)$$
I've tried this:
$$w(c - a - b) = (ab - d)$$
$$w(a + b - a -b) = ab - d$$
$$0 = ab - d$$
$$ab = d$$
But is this really an acceptable way of solving the solution? I am very confused. I've proved that the equations I found earlier (when I set w = 1 and w = 0) are true when w = w by putting it into the mother equation
Mathematics news on Phys.org
There are no fixed c,d, such that the equation is true for more than one w. If you know a,b,c,d, you can calculate w, it cannot be more than one value.
c=a+b is impossible, this would make the denominator zero.
Either you try something impossible, or it is unclear what you want to do.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
