How can I find the coefficient of x^12
  • Thread starter Thread starter DeathKnight
    Coefficient
To find the coefficient of x^12 in the expression (2+x)^{14}(1+ \frac{2}{x})^{14}, one approach involves rewriting the expression to identify terms contributing to x^12. The term T_{r+1} can be expressed as 14C_r (4)^{14-r}(\frac{4+x^2}{x})^r, where the binomial coefficient 14C_r is crucial. The key is to determine the values of r and s such that the powers of x combine to yield x^12, specifically by solving the equation 2s - r = 12. This method, while complex, allows for calculating the coefficient by summing the contributions from valid r and s pairs. The discussion emphasizes the challenge in simplifying the problem while maintaining accuracy in calculations.
DeathKnight
How can I find the coefficient of x^12 in:
I did it like that:
Can be written as:
(4+ \frac{4+x^2}{x})^{14}
Now the term T_{r+1} can be represented as:
14C_r (4)^{14-r}(\frac{4+x^2}{x})^r (How can I write 14Cr?)
Dont know where to go from here?
Thanks in advance for any help. :smile:
Mathematics news on Phys.org
There's more than one way to skin a cat:
how can you obtain x^12 from the two original brackets? You need x^14 from one and x^{-2} from the other and... add 'em up.
for the tex for binomial coeffs click on:
\binom{n}{r}
Thanks a lot for your reply Matt. I got what you said but I'm still curious to find out how can I find the answer to it by using the method I stated above? I have done many similar questions and I know I have to find the value of r for which the power of x is 12. Is this possible?
of course it is- just not very easy, you just need, for each r to find the positive integer s where 0<=s<=r, if it exists, such that 2s-r=12 and then add up, for each one where this happens,
\binom{14}{r}\binom{r}{s}4^{14-r}4^{r-s}
hardly elegant but then you made the problem much harder with your choice of "simplification"
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
