How can I find the shape of an orbit under an inverse cube law of force?
The discussion focuses on determining the shape of an orbit under an inverse cube law of force, specifically f(r) = ν/r³. The user successfully derived the relationship between r and θ using angular momentum, leading to the conclusion that if ν ≤ h², the orbit is unbounded. The approach involves substituting r with 1/u and differentiating to express the motion in terms of u and θ, ultimately simplifying the differential equation for easier resolution.
  • Understanding of classical mechanics, particularly orbital dynamics.
  • Familiarity with differential equations and their applications in physics.
  • Knowledge of angular momentum and its role in motion.
  • Proficiency in LaTeX for mathematical expressions.
  • Study the derivation of orbits under various force laws, including inverse square and inverse cube laws.
  • Learn about the implications of angular momentum in orbital mechanics.
  • Explore methods for solving differential equations in physics, particularly in celestial mechanics.
  • Investigate the stability of orbits and conditions for bounded versus unbounded trajectories.
Students and professionals in physics, particularly those focusing on celestial mechanics, orbital dynamics, and mathematical modeling of physical systems.
bushdayroses
I've found the a general form of equation for the explicit integration of the shape, [itex]r(\theta)[/itex], of a one-body-problem (a particle rotating about a set point, O) for arbitrary [itex]\mathbf{f} = -f(r)\hat{\mathbf{r}}[/itex], and used it to find [itex]r(\theta)[/itex] for an inverse square law [itex]f(r) = \mu / r^2[/itex]. Where [itex]u = (1/r)[/itex].
I was able to get [tex]r = r(\theta(t)) => \dot{r} = {{dr} \over {d\theta}} {{d\theta} \over {dt}} = {{dr} \over {d\theta}} \left({{h_0} \over {r^2}}\right)[/tex]
Where [itex]h_0 \neq 0[/itex] is the constant angular momentum.
Can anyone help me to figure out the shape under an inverse cube law of force, [itex]f(r) = {{\nu} / {r^3}}[/itex], and show that if [itex]\nu \le h^2[/itex], the orbit is unbounded?
I know that this solution will depend on the relative sizes of [itex]\nu[/itex] and [itex]h[/itex], but I can't seem to get this to work.EDIT:: Got LaTex to work
One way to approach this problem is to use the substitution
[tex]r=\frac{1}{u}\mbox{ and u =}\frac{1}{r}[/tex]
then differentiate r with respect to t giving
[tex]\dot{r}=-\frac{1}{u^2}\frac{du}{d\theta}\frac{d\theta}{dt}[/tex]
and
[tex]\dot{\theta}=\frac{L}{mr^2}[/tex]
This will give
[tex]\dot{r}=-\frac{L}{m}\frac{\mbox{d}u}{\mbox{d}\theta}[/tex]
Differentiate again with respect to t to find the second derivative of r in terms of u and theta. Write the general equation of motion for r in terms of F(r) and "centrigugal" force (L2/(mr3), and substitue the second derivative of r with respect to t. You will arrive at an equation of motion in terms of u and theta. This differential equation is easier to solve than straightforward methods. Once u is found substitue 1/r and solve for r.
Got it figured out. Thanks
  • · Replies 26 ·
  • · Replies 25 ·
