How Can I Increase the Amperage Output of an AC to DC Converter?
Increasing the amperage output of an AC to DC converter is generally limited by the ratings of key components, such as the transformer and rectifying diodes. Modifying existing equipment can lead to overheating and safety hazards, making it impractical for novices. Instead of attempting modifications, purchasing a more powerful, commercially available power supply is recommended. The output is constrained by the physical size of the transformer, and while lowering the voltage may yield slightly more current, it risks overheating. Overall, for higher power needs, investing in a larger transformer or a higher-rated power supply is the best solution.
bskramer
hey guy I was wondering if there was any way to increase the amperage output of an ac to dc converter, it is a 120v ac input that outputs 13v dc at 3.42 A. is there any way to boost this output?
P.S. Ya'll are the best, This is by far one of my favorite places to be on the web. kudos on a job well done.
The current available from a power supply of this kind will normally be limited by the ratings of certain key components. Exceeding these ratings is likely to result in failure, which can cause overheating, fire and electric shock hazards.
Modifying mains powered equipment is not a job for novices. It would probably be uneconomic to make the modifications needed, so even someone who knows what to do in principle would most likely buy a manufactured product. If you need a more powerful supply, you would be far better advised to buy one.
Generally that current output (and therefore power output) is limited by the physical size of the transformer in the linear power supply. The only way to get more power out is to buy a bigger transformer. The bigger transformer model will also come with bigger rectifying diodes.
If it's a switching power supply, it takes a bigger transformer and bigger switching semiconductors.
So the short answer is no.
EDIT -- Beaten out by Adjuster!
Nope... You get 13 * 3.42 = 44.46 watts from your wall-wart and that's it. You can probably get a bit more current if you can deal with the voltage being pulled lower than 13, but the poor thing will probably overheat eventually.
I don't know if size is a factor, but this site,
http://www.trcelectronics.com/12-volt-power-supplies-mid-chassis-1.shtml
was helpful when we needed a 12VDC supply with high current for a project. Since you want high power, it's hard to get too small in size, because, like everyone else said, the components are big at higher ratings.
Hope this helps.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
