How can I (safely) test this "toy" machine?
  • Thread starter Thread starter DaveC426913
32 replies · 4K views
DaveC426913
2025 Award
TL;DR
This toy ATV came untested. I want to make sure the motor works before bothering with anything else.
I picked this up for free for my grand-child. It allegedly worked when the previous owners last tried, but it's been sitting outside for at least many months.
It did not come with the charger. No idea of the condition of the batteries. I assume they're dead. I do have a battery charge for my car. Nevertheless, Before I put any effort into it, I should find out if the motor works at all. I want to separate any battery troubles from any motor troubles, so it seems to me I can just hook it up to my car batter(ies).
I found it here online: it says it is 24V.
https://goldtex.ca/products/peg-perego-polaris-ranger-rzr-green-shadow-24-volt-green
So ... I hook up two car batteries in series, right?
Any special precautions? Other than don't electrocute myself, or 'splode it in my face?
Two car batteries in series should work fine to test. You understand that the issue with car batteries is not electrocution (volts) but the fact that they can dump lots of amps if shorted causing lots of heat. Wear goggles/face shield and stout gloves when you first check it out.
Charge the old batteries slowly when you attempt their resuscitation. Good toy!
Reply
A fairly stout older battery charger should test the motor unloaded. I'd say if it turns unloaded at twelve volts with no squeals or other noises indicating mechanical issues, the motor is good.
Reply
Progress report:
  1. As far as I can tell, there is only one battery in this machine. For some reason I thought there were two. I guess it has a 12v > 24v transformer?
  2. I charged the battery for a few minutes. My charger said 'charging' for about 15 seconds and then said 'charged'. I am very skeptical. This battery has sat in weather for at least a year and probably hasn't been charged in much longer than that. What is the most likely scenario with my charger telling me it's charged?
  3. All that said, I tried it. As God is my witness, it turned over for one second. When I pressed on the gas, it zizzed like electric motors do and the wheels turned a fraction.
And then it died and will not restart. I charged the battery again for an hour but no joy. My first thought is it burned out a component on the PCB.​
The PCB:​
Looks like a couple of PTC self resetting fuses and some relays on that board. Unless a circuit board trace blew open, I'd think there's little to go wrong there. Don't give up on this. I think it can be brought back.
Oh one last thing, when you get it running please post a pic with you driving it? 😆
You bet I will!
I've found the manual online, which includes the wiring diagram, so I can start tracing connections.
Reply
Dave the add showed a 24V battery!! It definitely shows 24V
The behavior of the 12V charger is consistent with trying to charge a 24 V battery. As soon as it sees 13-14V it declares "charged".
The battery is not being charged and the behavior is consistent with a 24V battery just barely charged. You need the correct charger.
There would not likely be a transformer on the cart. What does your battery look like?
Reply
Oh. That's what 12v+12v means. Duh.
(That must have been what fooled me into looking for a 2nd battery.)
Of course. That's makes sense now.
So maybe there isn't anything wrong with the PCB. Maybe the battery had just enough juice to kick it over but no more - no matter how long I try to charge it.
On the first picture above it is one piece of battery pack consisting of two standard 12V 12Ah batteries :smile:
You might be able to get new batteries and rebuild the pack DIY.
Also, though it's not advised for regular use, you might be able to charge the batteries one-by-one with a 12V charger, just for a test run. Be careful with dismantling the pack.
DaveC426913 said:
I tried it ... it turned over for one second.
That means it'll likely move with a single 12V car battery too: it'll be enough for a quick test.
Mind the polarity.
Reply
Charger arrived today. Charged the battery for an hour, and gave it a shot.
It worked* !
*mostly
Drove it around for a few minutes (it's too small for me to get in. I have to stand.) Then charged for another hour.
It is pretty faulty. I have to jiggle and jam the gear shift to get any action, and even then it goes in fits and starts. It feels very much like a bad connection (either mechanical or electrical) right in the gear shift.
So after a mere ten minutes, it's stopped. Won't budge for love nor money.
First thing I want to do is test continuity of the wires; look for crimps & stuff. Never mind figuring out what is hooked up to power or whatever, can I use a multimeter to just test continuity of wires and connections?
Reply
Well, yeah ... I suppose you Could ... just keep in mind you have a good chance of letting all of the "Magic Smoke" out of the meter.
Reply
  • Haha
It worked* !
*mostly
Good stuff - you are fully committed now!!
So you can say that the original fault was not the battery. Can you look at the brushes on the motor? How is the speed control achieved? A huge variable resistor or something more sophisticated?
It was just a dead battery and no charger.
I will find out this morning if the battery is effed.
There's a pedal, but I'm not sure it has any granularity beyond 'Go' and 'Don't Go'. I won't know that until I can get it to run continuously for more two seconds at a time.
Just be careful where you go driving it... :wink:
Bad boys, bad boys, whatcha' gonna do...
No joy after another hour or two of charging. Which means I've jostled loose or fried something since the first test.
:pulls sleeves up: Time to get bizzy.
I've narrowed it down to this switch (as I originally suspected). At least for now.
It works in the REVERSE (i.e momentary ON position), but does not work in FORWARD (default OFF position).
I want to bypass the switch itself to see if I can get the FORWARD to work, but I'm not sure which pin(s) to jump.
You have an error on your drawing: Numbers 2 and 5 notations are interchanged. (The middle connections go to the motors and the left connections go to the battery.)
The following figure shows the internal connections depending on the switch position:
So connecting 1&2 and 3&5 together should bypass the switch in the forward direction. 1&3 and 2&5 should be the reverse direction.
Nope.
(5) runs directly to a fuse then to the battery terminal.
Here's a better pic:
In the little research I've done I can see that you are correct - it is not the conventional/correct way to do it. But for now, it is what it is.
Question:
This is what the switch actually does, yes?
It seems to me, I can
- disconnect the two ON (REVERSE) pins, then
- jump the OFF (FORWARD) pins.
If the motor works, then the switch itself is toast.
I wish I could just replace the switch, and guarantee it's working. Problem is, it's riveted in to the gear shift mechanism.Oh. I just saw this diagram:
jack action said:
I know they go where you say they go, but:
  • On the switch, 5 is on the left and 2 is in the middle;​
  • On the drawing, 5 is in the middle and 2 is on the left.​
Oh. Right. Fixed.
Now it makes a little more sense. Its still wired up backwards, but at least it's symmetrically backwards. :smile:
Well there's yer problem mister...
Looks like I'll be hard-wiring this puppy in forward gear...
:oldbiggrin:
Reply
Tom.G said:
A Google search finds many replacement switches, many <$10:
Just make sure they are rated for DC, and preferably for inductive load (hard to find though).
https://www.google.com/search?sca_e...t+50A+rocker+switch&oq=dpdt+50A+rocker+switch
Cheers,
Tom
Yes, I have Googled them muchly.
The catch is that the gear shift is designed to mechanically push on the switch - switch and gear shift are affixed in a framework so they come together just right. I don't think there's a lot of margin for error, so it has to be virtually the exact switch.
(The switch button itself is flat, not concave - not curved or notched - and it is opaque red, not transparent. Too bad I can't just point to a Google pic to show you what I mean...)
Also, it's 2-position, temporary-on. Most of those are 3-position.I have yet to find anything similar online.
Reply
OK.
Try inserting the word Momentary between 'dpdt' and '50A'.
Reply
Alas...
Even dpdt momentary 20A rocker switch 6 pin 12v brings only tears and heartbreak.
Reply
  • Care
OhGodNo. An adapter to convert our rack of Ryobi batteries to work with the Peg Perego...
"...and that was the last glimpse of her - magazine of full Ryobi batteries in the passenger seat next to her - as she headed for the horizon, still going pedal to the metal... Our little Sarah Connor..."
Reply
  • Haha
