How Can I Simplify the Expression cos(2n*pi)?
  • Thread starter Thread starter sara_87
The discussion revolves around simplifying the expression cos(2n*pi) and understanding its properties within trigonometry, particularly focusing on the behavior of the cosine function at integer multiples of pi.
  • Participants explore the relationship between cos(2n*pi) and known identities, such as cos(n*pi) = (-1)^n. There are attempts to clarify the periodic nature of the cosine function and its implications for the expression in question.
Several participants are engaging in a back-and-forth regarding the periodicity of the cosine function and how it applies to cos(2n*pi). Some have suggested that understanding the graph of the cosine function may aid in grasping the concept, while others are questioning the implications of periodicity on the expression.
There is an emphasis on the periodic nature of the cosine function, with references to specific values such as cos(0) and how they relate to the expression cos(2n*pi). Some participants express uncertainty about the notation and its implications, indicating a need for clarification on the relationship between the expression and its periodicity.
sara_87
what is cos(2n*pi)
I understand that cos(npi)=(-1)^n
so is cos(2n*pi)=2(-1)^n ??
Make the substitution m=2n in cos(mπ)=(-1)^m
so you mean cos(2n^2)=(-1)^2n
No, I mean cos(2n pi)=(-1)^{2n}
Do you know what cos(0) is? Do you know that cosine is periodic with period 2 pi?
yep cos0=1
yep, cos is periodic with period 2pi
So cos(2n pi)= cos(0+ n(2pi))= ?
oh right,
so =(-1)^(n+1)
is that right?
sara_87 said:
oh right,
so =(-1)^(n+1)
is that right?
No. Look at posts 4 and 7.
sara_87 said:
yep cos0=1
sara_87 said:
oh right,
so =(-1)^(n+1)
is that right?
Okay, what does "periodic" mean?
...I think it is necessary to know the graph of cos(x), which may help a lot. so, find one.
edit (:shy: trying not to be ambiguous)
...I think it is necessary for one to know the graph of cos(x), which may also help a lot. (regardless of this particular problem)...
"periodic" is really the key:approve:
It might help. It is not necessary. All that is necessary is to know what "periodic" means. No computation is required.
I understand that periodic means that cosine function repeats after multiples of 2 pi. but how would that have anything to do with writing cos(2n*pi) ?
cos (npi)=(-1)^n because as long as n is an integer, the value will alternate from -1 and 1 (clearly form the graph)
Would it be easier if it were written n*(2pi) rather than 2n*pi? This is about multiples of 2pi!
cos(2pi)= cos(0+ 2pi)= cos(0)= 1
cos(4pi)= cos(2pi+ 2pi)= cos(2pi)= 1
cos(6pi)= cos(4pi+ 2pi)= cos(4pi)= 1
oh right! so cos(n2pi) has to always be 1...i feel very stupid, i should have known that. for all n, cos(2npi) must be 1 as long as n is an integer.
thank you very much
