How can I tell if the source is AC or DC
  • Thread starter Thread starter Jason03
    Ac Dc Source
To determine if a source is AC or DC, consider the nature of the source; a 24 V battery indicates a DC source, as batteries are typically made from electrochemical cells. The transformer mentioned has a turns ratio of 8, but since the input is DC, the secondary output voltage is zero volts. The phrasing of the question suggests it was designed to mislead, as referring to an AC source as a "battery" is unusual. The conclusion is that a battery cannot produce an output voltage when connected to a transformer, confirming its DC nature. Understanding these distinctions is crucial for interpreting electrical sources correctly.
Jason03
A 24 V battery is connected to the primary input of a transformer having a turns ratio of 8. The voltage seen at the secondary output is:
Now how can I tell if the source is AC or DC from this question?
Good question. If the battery is made from electrochemical cells, it's DC. And I've never heard of an AC source referred to as a "battery". If they meant AC, it is a really weird way to word the question.
It was a bit of a trick question from my teacher...luckily I got it right...the answer is zero volts since a battery would be considered a DC source...therefore no output voltage
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
