How can ice cool an alcoholic drink below 0°C?
  • Context: High School
  • Thread starter Thread starter stinsonbr
    Cool Ice
The discussion centers around the phenomenon of how ice can cool an alcoholic drink to below 0°C. Participants explore the factors involved, including the temperatures of the ice and drink, the concept of equilibrium temperature, and the implications of freezing point depression. The scope includes theoretical reasoning and conceptual clarification related to thermodynamics and phase changes.
  • Some participants inquire about the temperature of the ice and its role in cooling the drink below 0°C.
  • There is a suggestion that the equilibrium temperature reached between the ice and drink depends on their initial temperatures and masses, with some arguing that the drink could reach a temperature below the ice's initial temperature.
  • One participant mentions the concept of freezing point depression as a relevant factor in the cooling process.
  • Another participant challenges the idea that the drink can cool below the ice's temperature, asserting that heat exchange will stop once both substances reach the same temperature.
  • There is a discussion about the melting of ice and whether the remaining ice can become colder as it melts, with differing views on the implications of this process.
  • Some participants propose that the final temperature can be below the initial temperatures of both the ice and the drink, depending on the freezing point of the liquid.
  • One participant introduces the idea of using dry ice and pressure as potential factors in cooling the drink.
  • Several participants express confusion about the thermodynamic principles at play, with requests for simpler explanations of the concepts involved.
Participants do not reach a consensus on whether the drink can cool below the ice's initial temperature. Multiple competing views remain regarding the thermodynamic principles and the effects of freezing point depression.
Some participants note the complexity of the interactions between different phases and substances, suggesting that the discussion may depend on specific conditions and definitions that are not fully resolved.
  • #121
Ronie Bayron said:
Final temperature of the alcoholic drink will be fixated at the temperature of the ice whatever it is and it can not surpassed that. Second law of thermodynamics limits the process. Even if you have a glass of alcohol, poured down inthe grounds of Antartica. It can't be any cooler than what is on the ground except if ice and alcohol has some sort of endothermic reaction when comes to contact.
Which, if you read this thread, turns out to be the case. Ice melting is an endothermic reaction.
Science news on Phys.org
  • #122
I mean the reverse rather. An exothermic chemical reaction perhaps
  • #123
Ronie Bayron said:
I mean the reverse rather. An exothermic reaction
I do not understand. You meant to say that an alcohol/ice mixture cannot reach a temperature below 0 degrees Celsius unless an exothermic reaction occurs, thereby cooling the system by adding heat?
  • #124
I am sure it could be either (Chet is able to explain this better, not my expertise) of the two that would effect that. If and only if alcohol reacts with water.
  • #125
You were right the first time. "Endothermic" is the one that drains heat energy and adds potential energy.
Alcohol and ice do interact. The ice melts into the alcohol, forming (or diluting) an alcohol/water mixture. That interaction is endothermic. It results in a lowering of the temperature of the mixture. If you read this thread from the beginning, that fact has been pointed out at length.
  • #126
The answer to the second one is no, unless you provided extra energy. This is the second law of thermodynamics.
  • #127
What are you responding to?
  • #128
I was replying to this
stinsonbr said:
I am not sure, if that would be a part of the answer then please explain it.
Let me word it this way: if I were making an alcoholic drink and took ice out of my freezer, put a few cubes in the drink and stirred, what factors could cool the drink to below zero?
Second question (if the first doesn't already answer it): would the drink be able to drop below 0°C if the drink was initially at room temperature, and the ice was initially at 0°C?
I meant to mark this as high school competency.
I thought I quoted :o
  • #129
Kyx said:
I was replying to this [message #3 in this thread]
Please read the entire thread. The temperature will, in fact, drop below 0 degrees without violating the second law.
  • #130
You can't. You could apply the principal of supercooling to a unopened bottle of beer or wine which is lower in alcohol with a higher water content. As trying to freeze 40% alcohol with an ice cube, well you just can't
  • #131
You are aware that this thread is not about freezing alcohol, correct? It is about mixing ice at 0C with a solution of alcohol and water at a temperature > 0C to lower the combined temperature to below 0 C. In this process, no freezing occurs, only melting of ice.
  • #132
Is the ambient temperature -114 Celsius?, otherwise the question is moot
  • #133
Let's see your equations. Mine are in post #99 for your consideration. Also, how do you explain Russ Waters' experimental results, in which his final temperature was about -6 C?
  • #134
Well I haven't seen Russ Waters experiment, but at a guess I would say that with the reduced latent heat a larger proportion of the ice would be able too freeze once nucleation begins, Like I said ambient temperature will also play a roll.
  • #135
Physics is an experimental science. If your prediction does not match experiments, it is wrong. Simply waving away experiments with a comment to the effect of "I have not checked" when the results are right there is not a valid excuse. To summarise it for you:
  • Start with ice at 0 °C and a water-salt mixture at > 0 °C.
  • Mix the two and observe the temperature of the final mixture.
  • Ambient temperature is > 0 °C but plays a minor role for the experiment anyway due to relatively good insulation.
  • Resulting mixture is < 0 °C.
Ignoring this experiment and the rest of the information which has already been posted in the thread only makes you appear ignorant.
  • #136
I thought we had water(ice) 0C and an alcoholic mix at 0C That experiment is not the same. I couldn't find the experiment results, too call another person ignorant is pretty condescending. by the way you should factor ambient temperarure with you're formulas. It would make it a bit more precise and a lot less bland.
  • #137
Russ' experiments are described in this thread. Apparently, you did not read the entire thread before you began expounding your own theory.
Now I told you that no freezing takes place in this system. So why are you talking about nucleation? No ice freezes (read my lips).
  • #138
Hence I stand by my first response. The question is moot sir.
  • #139
Huh?
  • #140
Not as condescending as ignoring 6 full pages worth of comments which have already been made in the thread is ignorant.
No, your answer is moot because it does not connect to the original topic. Nowhere is anybody claiming that you can freeze the alcohol.
  • #141
Let me explain the reality of the situation to you. You have 6 Physics Forums Mentors (Nugatory, Russ Watters, Dr. Claude, Drakith, mfb, Chestermiller) with over 100 years of combined experience and with both experimental results and theoretical modeling calculations to back them up arguing one way, and then there is little ol' you, with not equations, no calculations, no cited literature, and no experiments arguing the opposite way. Do you really think that what you are saying can be given credibility by those reading this thread?
Now, if you have any specific criticisms of what Russ did in his experiments or what I did in my thermodynamic modeling analysis, let's hear them.
  • #142
I have difficulty believing this thread.
It is a simple problem:
There exists something called energy. It is neither created nor destroyed. (For purposes of this discussion we will neglect mass-energy transitions.)
Adding energy to a system will raise the temperature. Taking it away will lower the temperature (again neglecting irrelevant exceptions).
The phase transition from solid and liquid also takes energy. It gives energy the other way around. This energy is called the heat of fusion.
Water ice freezes at 0º C. A water/alcohol mixture freezes at a much lower temperature.
So adding the mixture to ice melts the ice taking energy which must come from somewhere.
Under some circumstances the only place for it to come from is the water/alcohol mixture. Under other circumstances it could come from other places, but the OP question was, "Can this happen?", i.e. are there any circumstances? The answer is yes.
The heat of fusion of the ice is stolen from the drink, potentially making it colder than 0ºC.
As others have pointed out, ice cream was made this way (using salt, not alcohol) for centuries. This isn't new or disputed science. It's something everyone in the world with ice, salt, and a thermometer can check for themselves.
Get a thermometer. Go to a bar. Buy a drink. Isn't science tasty.
  • #143
Still, 142 posts ( 143 inclusive ) on the subject.
Freezing point depression is a mis-understood phenomena, both by beginers and the well-heeled.
Probably because it is mostly described as a laboratory demonstration starting from a mixture at a temperature, and then cooling the mixture and noticing the formation of cyrtals forming at a subdued temperature from the pure solvent.
  • #144
What do you mean? The consensus of those doing the math and the experiments in this thread agree with you. The temperature of the mixture will drop.
  • #145
I think he's expressing surprise at the level of incredulity.
  • #146
Well butter my biscuit... :rolleyes:
  • #147
Jeff,
I'm impressed by your perceptiveness, and your ability to recognize the solution to this "obvious" (to you) problem. Unfortunately, it was not so obvious to naive me (and many other mere mortals). At least at the beginning, it wasn't obvious to me that, as the ice melted, its temperature would be dropping.
When you made your knowledgeable pronouncement, were you aware that solutions of ethanol and water are highly non-ideal, and that the enthalpy of these solutions is a complicated non-linear function of the mole fraction of ethanol and temperature? Had you ever seen a diagram of the excess molar enthalpy HE vs temperature and mole fraction, and had you taken the behavior shown in these diagrams into account quantitatively when you made your pronouncement?
  • #148
Two words: "Apple jack."
  • #149
Chestermiller said:
Jeff,
I'm sorry, I woke up in a bad mood. I should have been more polite. Perhaps I should have done the experiment before posting (though posting while drunk has other problems).
  • #150
Okay, maybe it is one word ... Chet, chemical engineers are supposed to know these things.
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 32 ·
