How Can Input Power Improve Predictions in Scroll Compressor Modeling?
The discussion revolves around modeling a water-cooled scroll compressor, specifically focusing on predicting output conditions such as discharge pressure and temperature based on input power. Participants explore the challenges of data collection and the need for alternative methods to obtain necessary parameters for accurate modeling.
  • Ariel seeks to predict outlet conditions of a scroll compressor using limited data, including inlet and discharge pressure, outlet temperature, and water mass flow rate.
  • One participant suggests collecting throughput mass flow and inlet temperature to simplify calculations.
  • Ariel expresses difficulty in obtaining the necessary data, prompting the search for alternative methods.
  • Another participant emphasizes the importance of knowing the air mass flow for a proper energy balance and suggests fitting a flow meter to measure it.
  • Ariel clarifies that the system is a cryogenic cooling unit for nitrogen liquefaction using helium, and mentions the challenge of fitting a mass flow meter.
  • A later reply discusses the characteristics of a screw machine compressor, noting that mass flow can drop due to slip during operation and suggests obtaining data from the manufacturer.
Participants do not reach a consensus on the best approach to model the compressor, with multiple competing views on data collection and modeling strategies remaining unresolved.
Participants highlight limitations in data availability and the challenges of accurately measuring mass flow, which may affect the modeling process. There are also dependencies on manufacturer data for accurate predictions.
Individuals interested in compressor modeling, cryogenic systems, and those facing similar challenges in data collection for engineering applications may find this discussion relevant.
Arielkadiayi
Hi,
I am currently trying to model a water-cooled scroll compressor but do not have enough data to predict output conditions.
At the moment, I can collect inlet and discharge pressure, outlet temperature, water mass flow rate as well as inlet and outlet temperature.
I would like to be able to predict outlet conditions, (Pdischarge and T2) knowing the input power to the compressor experimentally since it takes quite a lot of information to model it geometrically.
Thanks,
Ariel
Collect throughput mass flow and inlet temperature as well . Then it's just simple sums .
Thanks for your reply. However, I have not been able to do that at least for now. That's why I'm looking for an alternative.
Without knowing the air (?) mass flow there is no way of doing a proper energy balance .
I'm sure that there is a way of finding this mass flow - after all it is constant anywhere in the system from first inlet to final discharge .
Any way of fitting a flow meter to inlet or discharge ??
It's a cryogenic cooling unit for nitrogen liquefaction using helium as the refrigerant. I hope to later on back calculated the Helium mass flow rate knowing the amount of nitrogen liquefied but still that wouldn't be accurate. At the moment I can't fit a mass flow meter unfortunately!
Hi Ariel, welcome to the board,
Arielkadiayi said:
Hi,
Thanks,
Ariel
A screw machine is a positive displacement type of compressor but it will have considerable slip during operation so mass flow drops as discharge pressure increases. The manufacturer should be able to give you discharge pressure and temperature along with flow rate for any condition. You'll need to know what that is before you can try and model it because the slip will vary depending on pressure differential and could be quite large.
Can you get mass flow from the manufacturer, and if you can, why do you need to create your own model?
17K
