How can the wave equation be rearranged to include r?
  • Context: Graduate
  • Thread starter Thread starter Botttom
    Wave Wave equation
The discussion centers on rearranging the wave equation to incorporate the radial coordinate \( r \) in the context of spherical waves. Participants explore the implications of this rearrangement, including the conditions under which it is valid and the nature of solutions derived from it.
  • One participant presents the wave equation and seeks methods to rearrange it to include \( r \).
  • Another participant notes that the rearrangement is only valid for spherical waves, requiring the Laplace operator to be expressed in spherical coordinates.
  • Some participants express interest in finding solutions using the rearranged equation, while others emphasize the need for initial conditions to obtain specific solutions.
  • A participant proposes that if \( \phi \) is a solution, then each partial derivative of \( \phi \) should also be a solution, but struggles to demonstrate this through substitution.
  • There is a suggestion to apply the product rule to derive the necessary results, with some participants questioning the application of this rule in the context of the wave equation.
  • Another participant introduces a general solution for \( \phi \) in terms of \( r \) and time, but acknowledges uncertainty regarding its applicability.
  • Discussion arises around the independence of \( r \) and the implications for partial derivatives, with some participants attempting to connect these derivatives to trigonometric functions.
Participants generally agree on the need for specific conditions to derive solutions from the rearranged wave equation, but there are multiple competing views on the validity of certain approaches and the implications of applying the product rule. The discussion remains unresolved regarding the exact nature of the solutions and the application of derivatives.
There are limitations regarding the assumptions made about the nature of the wave and the dependence on angular coordinates. The discussion also highlights unresolved mathematical steps in demonstrating the properties of the partial derivatives of \( \phi \).
Botttom
Hello!
The wave equation given: [itex]{1\over{c^2}} {\partial^2 \phi\over{\partial t^2}} = \Delta \phi[/itex] with [itex]r = \sqrt{x^2+y^2+z^2}[/itex] needs to be rearranged, so that [itex]{1\over{c^2}} {\partial^2 ( r \phi) \over{\partial t^2}} = {\partial^2 (r \phi) \over{\partial r^2}}[/itex].
Are there any tricks to obtain this result?
This is only possible if you have a wave which does not depend on the angular coordinates in spherical coordinates, i.e., a spherical wave. Then you need express the Laplace operator in spherical coordinates.
Yes, this works!
Is it possible to find solutions using the second formula?
Thanks!
it sure is but you're going to need to specify some initial conditions otherwise your solution can be any periodic function whatsoever that solves the wave equation...
I would like to show, that if [itex]\phi[/itex] is a solution to the equation than each partial derivative of [itex]\phi[/itex] is also a solution.
I am failing to show that just by plugging the derivative in. How can i do that?
The product rule should give you this result
Do you mean product rule in this formula>?
could you link the exact wording of the question?
without actually doing it my intuition suggests that to check that a partial derivative of phi solves the equation, make the substitution $$\phi \rightarrow \frac{\partial\phi}{\partial r}$$
or $$\phi \rightarrow \frac{\partial\phi}{\partial t}$$
and then apply the product rule.
The question is to show, that if [itex]\phi[/itex] solves the equation [itex]{1\over{c^2}} {\partial^2 ( r \phi) \over{\partial t^2}} = {\partial^2 (r \phi) \over{\partial r^2}}[/itex]
than so should every partial derivative $$\frac{\partial\phi}{\partial x }, \frac{\partial\phi}{\partial y }, \frac{\partial\phi}{\partial z }, \frac{\partial\phi}{\partial t }.$$
And it seems that the product rule has to be applied here for more than 20 times, but i still don't get the result.
maybe write the general solution for the product ##r\phi## then take derivatives?
Yes, but the general solution is not known in this case
The general solution is ##\phi = \frac{Au(r-ct)}{r} + \frac{Bv(r+ct)}{r} ##
Perhaps I have misunderstood the problem but anyway. Since r is independent the partial derivative of ##\phi## with time is obviously a solution.
## \partial^{2}_{t}(r\partial_{t}\phi) = \partial_{t}(\partial_{t}^{2} (r\phi)) = \partial^{2}_{r}(r\partial_{t}\phi) = \partial_{t}(\partial_{r}^{2} (r\phi)) ##. Now do the same with the other partial derivatives. I think we get something along the lines of ## \partial_{t}^{2}(\cos(\theta)\phi) = \partial_{r}^{2}(\cos(\theta)\phi) ## in 2 dimensions.
Well , yes the part with the time derivative is obvious. The other part is not.
Why would there be a cosine(theta) ?
It would be from ## \partial_{x}r = \cos(\phi) ##. Isn't that correct?
oh you mean $${\partial r\over {\partial x}} = {x \over r} = {r \cos(\theta) \over {r}} $$
  • · Replies 36 ·
