How can you determine the following limit
  • Thread starter Thread starter OmniNewton
    Limit
OmniNewton
How can you determine the following limit using rationalization?
where x = h
I attempted to multiply by the conjugate and cannot get the problem to work out. When doing this I noticed no terms canceled out and now I am stuck.
We have not use l'hopital's rule in our class and I am wondering how I can solve this problem without derivatives.
I simplified the limit to the following state:
Additionally, I tried taking the conjugate of the numerator as well. The problem is every substitution leads to 0/0
Do you mean the following?
\lim _{h \to 0} \frac{\sqrt{h^2 + 15} - \sqrt{h + 15}}{\sqrt{h + 3} - 2}
yes
OmniNewton said:
How can you determine the following limit using rationalization? lim x--> 0 (h^2 + 15)^(1/2) - (h + 15)^(1/2) divided by (h+3)^1/2 - 2.
Is the limit supposed to be evaluated as x → 0 or as h → 0?
In the expression above, there is no x variable.
Sorry that is a extremely simple mistake you are correct as h--->0
Have you tried simply plugging h = 0 in?
My bad the problem is actually h----> 1 I have been looking at the problem for 2 hours :p
You don't necessarily need terms to cancel out when you multiply by the conjugate. What you need to do is ensure that you're not dividing by 0. It would help to show your work when you do that.
OK I will post a screen shot of my work
So, notice what's causing difficulties. You want to make sure you don't divide by 0, but multiplying by the conjugate of the numerator won't take away that term in the denominator that goes to 0. So perhaps try multiplying by the conjugate of the bottom.
Sometimes, a limit can be evaluated by simply plugging in the limit value, as suggested by axmls. It's only when you get either an infinite or otherwise undefined result by substitution that you need to resort to more subtle manipulations.
Hi, I tried taking the conjugate of the bottom and a similar problem has occurred:
The problem is still of the form (0/0) when substituted in
How can you not divide by zero if the zero term is not eliminated?
Well, this problem keeps changing, for some reason.
Sorry it should have only been that one change to make it so h---> 1 instead of h---> 0
No, no, please don't. Screen shots are discouraged; typing it all out is much preferred, because the results are essentially device-independent.
The following limit should actually simplify to this:
I figured out the solution! One must multiply the equation by both conjugates!
Thank you for the Guidance.
Right, in that you need to use both the conjugates, the one for the numerator as well as the one for the denominator.
By the way, it's not a equation. An equation has two sides separated by an equal sign.
