How Can You Prove tan(x) = x Has Exactly One Solution in Each Interval?
  • Thread starter Thread starter frankpupu
The discussion revolves around proving that the equation tan(x) = x has exactly one solution in the intervals of the form (nπ - π/2, nπ + π/2) for integer values of n. Participants are exploring analytical methods to establish this without graphing.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of Rolle's Theorem and the implications of the derivative of the function f(x) = tan(x) - x. There are attempts to analyze the behavior of the function and its derivative to establish the existence and uniqueness of solutions.
The discussion is ongoing, with participants questioning the necessity of using Rolle's Theorem and clarifying the conditions under which it applies. Some guidance has been provided regarding the need to show that the function changes sign within the interval, indicating the presence of at least one solution.
There is some confusion regarding the application of the derivative and the conditions for Rolle's Theorem, as well as the interpretation of the problem statement concerning the number of solutions in each specified interval.
frankpupu
for the equation tanx=x in (npi-pi/2,npi+pi/2)for n is integers. show that it has precisely one solution.
without ploting the graph. use analysis
i have try to assume two solutions then apply the rolles theorem but i cannot do in this way since assume two roots c1 and c2 then exists c s.t. f'(c)=o but f‘(x)=(tanx)^2>=0
can someone give me some helps
Look at the function f(x) = tan(x) - x.
Where are you getting f'(x) = tan2(x)?
for f(x)=tanx-x
then in the range (npi-pi/2,npi+pi/2)
it is differentiable
then f'(x)=1+(tanx)^2-1=(tanx)^2
You mean (secx)^2 right?
Edit: Oh no, you're right.
ok i get it thank you yes (secx)^2 then it will always greater than 0
First you need to show (i) the equation has at least one solution. Then you need to show (ii) it cannot have more than one solution. Hint for (i): can you show the function tan x - x changes sign in the interval?
RGV
sec2(x) is always >= 1.
now i get confused again sec^2>=1 then sec^2-1 >=0 but we assume that we have 2 roots and use the rolles theorem then f'(c)=f'(d)=0 it means that it can have two root . how can i prove that only one root?
Maybe I'm being dense, but I don't see why you think you need to use Rolle's Theorem. For that theorem, the conditions are that f(a) = f(b) = 0 (plus some other conditions), where a and b are the endpoints of some interval.
Furthermore, I don't think you have stated the problem correctly.
In each of the intervals (n[itex]\pi[/itex] -[itex]\pi[/itex]/2, n[itex]\pi[/itex] + [itex]\pi[/itex]/2) there is a solution of the equation tan(x) = x, so in all of these intervals there are an infinite number of solutions. Do you need to show that in each interval there is exactly one solution?
If so, you can show this by looking at the derivative, and by determining whether the function itself changes sign, which is something Ray Vickson suggested a few posts back.
