How Did the (2π)^2 Term Arise in the Casimir Force Derivation?
kenkhoo
Derive the Casimir Force on each plate, for a two parallel plate system (L x L), separated at a distance of 'a' apart.
The solution was found in en.wikipedia.org/wiki/Casimir_effect#Derivation_of_Casimir_effect_assuming_zeta-regularization. (sorry I couldn't include link yet). Now my question is how did the (2∏)^2 came out in the integral for <E>,
I would think it as the constant from Fourier transform but I was unable to prove that. Any idea how did that thing pop up of nowhere?
oh this question is moot. It's basically multiplication of the DOS.
Thanks anyway
Assume a large hypercubic box in d dimensions of length L. Impose periodic boundary conditions (PBCs) on any function:
<br /> \psi(x_1 + L, x_2, \ldots, x_d) = \psi(x_1, x_2 + L, \ldots, x_d) = \ldots = \psi(x_1, x_2, \ldots, x_d + L)<br />
Then, we can expand the function in multidimensional Fourier series:
<br /> \psi(\mathbf{x}) = \sum_{\mathbf{k}}{c_{\mathbf{k}} \, e^{i \mathbf{k} \cdot \mathbf{x}}}<br />
where
<br /> \mathbf{k} = \frac{2\pi}{L} \langle n_1, n_2, \ldots, n_d \rangle<br />
is a multidimensional wave vector that can take on discrete values.
In an interval (k_i, k_i + dk_i) of the ith component, there are
<br /> dn_i = \frac{L}{2\pi} \, dk_i<br />
To find the total number of states within an infinitesimal volume of k space
<br /> dn = \mathrm{\Pi}_{i = 1}^{d}{dn_{i}} = \frac{L^{d}}{(2\pi)^{d}) \, d^{d}k<br />
So, the famous factor L^{d}/(2\pi)^{d} gives the density of states in k space.
Ah. Yeah I've forgot about the DOS.
Thanks for the detailed explanation!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
