I How did the Greeks deal with sqrt(2)?
  • I
  • Thread starter Thread starter musicgold
The Greeks recognized the existence of irrational numbers, such as √2, but struggled with their implications due to their philosophical beliefs that all numbers should be expressible as ratios of whole numbers. They often approximated irrational numbers for practical applications, using methods like the Babylonian method and the Euclidean algorithm to find approximations. Euclid's Elements, particularly Book X, addresses the conceptualization of irrationals geometrically, demonstrating constructions that result in incommensurable lengths. The Greeks did not classify these lengths as numbers in the modern sense but rather noted that they lacked a common measure. Overall, their approach combined approximation with geometric reasoning rather than numerical representation.
musicgold
I read the story of Hippasus's proof which showed ## \sqrt {2} ## is neither a natural number nor a ratio of natural numbers and how he was drowned by the Pythagoreans for his impiety.
My question is as the Greeks did not know about decimals (until a few centuries later), how did they deal with irrational numbers when they presented themselves in their calculations and measurements.
How do you deal with a quantity that can't be represented using existing methods? Did they just drop those calculations or approximate the number?
Thanks
Mathematics news on Phys.org
I haven't read the text yet, but this is the subject of Book X of Euclid's Elements, the content of which is most often attributed to Theaetetus. It is the longest book in the Elements and, according to Victor Katz (author of A History of Mathematics) it is the most well-organized. You can read a translation here which includes a guide to many propositions.
I'm currently at the end of book VIII so I'll hopefully be there soon...
Thanks
The story about Hippasus is an interesting account but its historical accuracy, as far as I know, is not certain. In any case, it turns out that Greeks knew about irrational numbers - see also Zeno's paradox. Pythagoreans just didn't like the idea because it was against their philosophy that natural numbers and their ratios describe the physical laws. Now, again as far as I know, Pythagoreans indeed try to approximate the value of ##\sqrt{2}## with high precision but unsuccessfully - for instance see the relevant table that depicts their method at ancient.eu.
Likes Klystron
Thanks
Note that the OP's question is about 'dealing' with irrational numbers. There is no question that the ancient Greeks knew about irrational/incommensurable numbers.
So, if by 'deal' we mean 'approximate them for practical application' (for no one would need an exact irrational number for practical constructions or calculations) then there was no challenge for them in doing this. One method they were probably aware of for doing so was the Babylonian Method. Another method that could be used is the Euclidean Algorithm (Propositions VII.1 and VII.2 of the Elements). This algorithm finds the greatest common divisor between two numbers. When applied to incommensurable magnitudes one finds that the method does not terminate and this would provide a way to approximate the value of an irrational number. However, my understanding is that the ancient Greeks were not concerned much with calculation. They were more interested in determining rational, universal truth.
So, if by 'deal' we mean 'conceptualize the existence of' then that is what Book X of the Elements is probably a good reference for this. But, even in the earlier books of the Elements Euclid has to 'deal' with irrationals, and this is all done geometrically. For example, take the construction of the Mean Proportional between any two straight lines. Such a construction will often result in incommensurable lengths. Euclid gives a proof of this construction at least two times in the Elements (end of book II is the first appearance, with a more elegant one given later that the link above summarizes).
Likes musicgold
You seem to be working under a strangely widespread and persistent confusion about what irrational numbers are. There is nothing in the definition of irrational numbers that says anything at all about decimals or decimal digits.
DEFINITION: An irrational number is a number that is not a quotient of two integers.
For example, ##12/7## is rational since ##12## and ##7## are integers.
The most well known ancient Greek proof of the irrationality of ##\sqrt2## is this: If ##\sqrt2 = \dfrac a b## for some integers ##a,b##, where the fraction ##a/b## is in lowest terms, then at least one of ##a,b## is odd. So ##\left(\dfrac a b \right)^2 = 2##; hence ##a^2 = 2b^2##; hence ##a^2## is even; hence, being a square, ##a^2## is a multiple of ##4##; hence ##2b^2## is a multiple of ##4##; hence ##b^2## is a multiple of ##2##; hence ##b## is even. But this contradicts the fact that mentioned earlier, that at least one of them is odd. Hence the assumption that ##\sqrt2## is rational leads to a contradiction.
But the Greeks didn't consider non-integer lengths to be numbers; they didn't say that this number is irrational; rather than said the the lengths of the side and the diagonal of a square have no measure in common, i.e. no line segment would go into both of them some whole number of times.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
