How Do Elastic Collisions on a Frictionless Ring Affect Object Velocities?
  • Thread starter Thread starter luma
    Mean
In the discussion about elastic collisions on a frictionless ring, participants analyze the velocities of two balls after they collide. The calculations show that the post-collision speeds are consistently -1 m/s and 4 m/s, raising questions about the implications of these results. It is clarified that while momentum and energy are conserved, the same velocities in subsequent collisions suggest the balls would theoretically pass through each other. The conversation highlights the distinction between mathematical solutions and physical reality, noting that one solution may be non-physical in certain collision scenarios. Ultimately, the understanding of collision dynamics on a ring is reinforced through this examination.
luma
[PLAIN]http://img219.imageshack.us/img219/6725/diagramt.png
So I was doing this usual physics type question thing which goes along the lines kind of like this:
2 balls are constrained to a frictionless ring and collide elastically. What is their after velocities? Easy question using,
\frac{1}{2}m_{1}u_{1}^{2}+\frac{1}{2}m_{2}u_{2}^{2}=\frac{1}{2}m_{1}v_{1}^{2}+\frac{1}{2}m_{2}v_{2}^{2}
m_{1}u_{1}+m_{2}u_{2}=m_{1}v_{1}+m_{2}v_{2}
I got the (correct) answers of -1 and 4 for the after speeds.
The thing that confuses me, is that since the collision is elastic, if we repeat it for the next collision that happens on the ring then we will get the same answers of -1 and 4... What does this mean? It's saying that the balls will just pass through each other?
You might want to check your original "correct" answer. Just doing the math in my head your momentum is not the same before and after the collision.
Yes it is. The book even says it's correct.
Energy before = 50J
Energy after = 50J
Momentum before = 20 kg m/s
Momentum after = 6*4 + 4*(-1) = 24 - 4 = 20 kg m/s
What I'm asking is that since the momentum and energy are conserved, if you do the calculations for a subsequent collision you will get the same velocities. But that sounds absurd and nonsensical!
Like if A is traveling 4 m/s CCW (counter clockwise), and B travels 1 m/s CW, then after they loop round and meet each other again... they are still 4 m/s CCW and 1 m/s CW! Why? That must be nonsense as it implies the balls passed through each other
hi luma! :smile:
No, you get two "mathematical" solutions in each case, (5,0) and (-1,4).
You reject the first solution as non-physical in the odd-numbered collisions (technically, it is physical, and would apply if the balls somehow missed each other), and the second solution in the even-numbered collisions …
the 6kg ball keeps stoppping. :wink:
ahhh! yes, yes I did! very good! thanks :D Makes sense woo
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
