How do entanglement experiments benefit from QFT (over QM)?
473 replies · 41K views · last reply
vanhees71 said:
Of course the formalism does not supply a causal mechanism for the correlations in the sense you seem to imply (but not explicitly mention to keep all this in a mystery ;-)), because there is no causal mechanism. The causal mechanism is the preparation procedure...
I "think" what you mean is that the causal mechanism (such as it is, what you can control) essentially ENDS when the 2 photon entangled state begins. Because there is no known root cause (in any theory I know of) that explains* what the entangled outcomes would be for the various possible observations. In other words: you might be able to create the entanglement initially, but what happens "next" cannot be considered causal or deterministic via the formalism. And I naturally agree with that view, if I am close to what you mean.
And you have then said that "leads to a two-photon state, where both the momenta and the polarization of these photons are necessarily entangled." And you agree that 2 photon state is not classical, so we are in good agreement to this point. The only gap remaining :smile: is acknowledging that whatever happens next is an example of a) apparent randomness; and b) quantum nonlocality, things which MUST be present/embedded in any theoretical framework - even if to say the mechanism is unknown currently. We don't know a) why you get spin up, for example (or any value of a measurement on an entangled basis). And we don't know how the system evolves from a 2-photon state (spin/polarization undefined) to 2 matching 1-photon pure states whose distance/separation precludes influences limited by the light cone defined by a measurement.
You don't see a) and b) as mysteries, OK. We can agree that mysteries are in the eye of the beholder. :smile:*Even in MWI there is no explanation of why we see a particular outcome; and in BM there is no possibility of observing the pilot wave that guides a particular measurement outcome.
And just because it's not deterministic doesn't mean we can have no more knowledge about it. There are plenty of statistical systems we can characterize partially (like thermodynamic ones).
To me it all leads to chemistry and there are plenty of mysteries w/respect to how chemistry does what it does - like create observers who think up a name for it called "chemistry" then notice that it has to behave with relativistic symmetry and think up names for all the symmetries involved, but can't figure out how it does it.
atyy said:
But the thermal interpretation is not (yet?) a standard interpretation. I do agree that what you say would likely be true of an interpretation that solves the measurement problem (eg. maybe something like Bohmian Mechanics or the thermal interpretation, but that is also not a standard interpretation at this time).
Well, there is only one standard interpretation, printed in many different textbooks, and that is obviously far too idealistic, for example claiming measurements to be described by exact eigenvalues attained via Born's rule rather than by POVMs. (See the quote from Asher Peres in another thread.) Thus one cannot base arguments solely on the standard interpretation.
The thermal interpretation, though nonstandard, indeed solves the measurement problem, without introducing variables not already ubiquitous in QM and QFT. See Section 3 of Part IV of my sequence of papers.
vanhees71 said:
The only thing that has to do with a human experimenter is that he decides what he wants to measure, and there's no subjective element in this
vanhees71 said:
But why don't you ask? Is it, because the classical-physics description has no irreducible probability element in it?
These are closely linked.
It's because the quantum formalism says the statistics of the variables you choose to measure are not marginals of the set of variables in general. Thus if in an experiment on entangled particles we can measure ##A, B, C, D## (##A,B## being Spin measurements on the first particle and ##C, D## being spin measurements on the second) then if we measure ##A, C## we find ##p(A,C)## is not a marginal of ##p(A, B, C, D)##.
That's the difference between QM and even a stochastic classical theory. It means the sample space is determined by your choice of what to measure.
vanhees71 said:
Of course the formalism doesn not supply a causal mechanism for the correlations in the sense you seem to imply (but not explicitly mention to keep all this in a mystery ;-)), because there is no causal mechanism. The causal mechanism is the preparation procedure. E.g., two photons in the polarization-singlet state are created in a parametric downconversion event, where through local (sic) interaction of a laser field (coherent state) with a birefringent crystal a photon gets annihilated and two new photons created, necessarily in accordance with conservation laws (within the limits of the uncertainty relations involved of course) leads to a two-photon state, where both the momenta and the polarization of these photons are necessarily entangled. There's nothing mysterious about this. The formalism thus indeed describes and in that sense also explains the correlations. By "explaining" in the sense of the natural sciences you always mean you can understand it (or maybe not) from the fundamental laws discovered so far. The fundamental laws themselves (in contemporary modern physics mostly expressed in terms of symmetry principles) are the result of careful empirical research and accurate measurements, development of adequate mathematical models/theories, their test and, if necessary, refinement.
We know how to create and test a Bell basis state, that is not in dispute. It looks like you conflate the causal mechanism for creating a Bell basis state with the causal mechanism needed to account for the conservation principle it represents. As it turns out, the mechanism that creates the Bell basis state provides no mechanism to account for its conservation outcomes, which caused Einstein to believe quantum mechanics is incomplete (Smolin going so far as to claim it's "wrong").
For example, suppose we're talking about the (fallacious) "classical counterpart" to the spin singlet state, i.e., we have conservation of angular momentum in the classical sense. Alice and Bob would measure variable deflections through their SG magnets corresponding to some hidden underlying value of L for each particle, the sum of those hidden, underlying L's being zero per the creation of the state via conservation of L. In that case, the mechanism creating the state also provides a mechanism to explain the subsequent measurement outcomes in each trial of the experiment. Of course, with the real spin singlet state the conservation principle only holds on average when Alice and Bob make different measurements, since they both always measure +1 or -1 at all angles (no partial deflections as in the classical case, which uniquely distinguishes the quantum and classical joint distributions). [See our paper here or video summary here or here.] There is not anything in the mechanism creating the spin singlet state that also provides a mechanism to account for this manner of conservation.
I realize you don't need a causal mechanism to account for the average-only conservation to feel as though you "understand" quantum theory. But, the plain and simple fact is that others do. Thus, they don't understand why you're happy and you don't understand why they're not happy. The psychological needs of these two camps are different, that's all.
I'm writing all this because psychologically speaking, I've a foot in each camp. That is, I can live with acausality at the fundamental level, but I want a principled ontology for it. That's introduced in these two episodes of the video series (Episode 1 and Episode 2).
vanhees71 said:
It is impossible to explain any physics without invoking "the formalism". This is as if you forbid to use language in communicating. It's impossible to communicate without the use of the adequate language, and the major breakthrough in men's attitude towards science in the modern sense is to realize, as Galileo famously put it, that the language of nature is mathematics (particularly geometry), and this is the more valid with modern physics than ever.
We have the formalism and have seen that it maps to the experiments, which is the first step in understanding the phenomenon. That doesn't explain the phenomenon for everyone, as I just stated, but it is a necessary first step.
DarMM said:
Quantum theory breaks Kolmogorov's axioms. A quantum state and a context induce a Kolmogorov model via a Gelfand homomorphism.
Yes - you can look on QM as a generalized probability model, or, as is usually done, ordinary probability plus other rules eg at the semi popular level:
https://www.scottaaronson.com/democritus/lec9.html
I suspect it's trying to tell us something - what I have no idea. I do know that QM as we know it requires continuity in pure states, which you can't do in ordinary probability theory. This allows many powerfull theorems right at the foundations of QM eg Wigner's theorem. But why is nature so mathematically accommodating? I have a sneaky suspicion nature is running us in circles on this one because it turns out to be equivalent to requiring entanglement.
https://arxiv.org/abs/0911.0695
Thanks
Bill
Personally I would use not well known rather than standard. I do not think there is any standard interpretation other than the math itself. And yes I do realize you need some kind of interpretation of probability to apply it but that's true of many areas that use probability. You can prove all sorts of interesting things from the Kolmogorov axioms alone such as Brownian Motion is continuous but not differentiable anywhere (thats as far as I got with rigorous probability theory) but applying it is another matter as Ross's Probability Models makes only too clear (groan some of his problems are HARD - I took it at uni only because I liked the lecturer - never did like the subject).
Thanks
Bill
Brownian motion is continuos on the level of pure states.
Don't take the finite dimensional caricature of QM presented by quantum information theory as the full truth!
Thanks
Bill
The standard interpretation is still one of the Copenhagen flavors, usually without the collapse postulate. It's pretty close to the minimal interpretation and usually dubbed "the orthodox interpretation". With "standard interpretation" I mean the interpretation used by the majority of theoretical and experimental physicists (even in the quantum optics/AMO community, which are closest to the foundations).
The entangled state is as causal as any other. QT is a causal theory, as any dynamical theory of physics. The entangled state evolves according to the standard dynamical laws of QT as any other state.
You are always insisting on classical interpretations, not I! That's the main source of our mutual misunderstandings and quarrels. I just take QT seriously and I deny any necessity of classical interpretations. Particularly Bell's class of local deterministic (usually dubbed "realistic", which is a misleading term however) are ruled out with humongous significance while QT is confirmed!
The theory also clearly says what's random and what is not random. An observable takes a determined value according to the state preparation if and only if the outcome of the measurement leads to one value with 100% probability. Otherwise it's indetermined, and the outcome of any individual measurement is irreducibly random. When repeated on an ensemble of equally prepared systems the outcomes of these measurements are distributed according to the probabilities the state describes, and the state describes these probabilities and nothing else. According to QT, and confirmed by all Bell tests with high significance, there's nothing "behind the curtain" which could "determine" values of such observables.
Ad a) The randomness is not apparent but an objective fact of the behavior of nature.
Ad b) Interactions are local. What's called "nonlocal" refers to correlations between far distant parts of a quantum system described by entanglement.
There's nothing weird with this. It's just what we have figured out over the last 500 years about how nature behaves.
Yes sure, but it's an established fact of 100 years testing QT. For me that's the only conclusion I can come to in view of all the Bell tests disproving local deterministic HV theories and confirm QT.
There is no classical counterpart of spin. Spin is generically quantum, but that's semantics.
Indeed, I think the great merit of the scientific method is that it doesn't care about our psychological needs but establishs clear facts about what's real. Obviously the worldview of classical physics is not describing reality accurately. QT describes it at least more accurately. It may be psychologically problematic for you to face this reality, but I indeed wonder why.
A. Neumaier said:
Brownian motion is continuos on the level of pure states. Don't take the finite dimensional caricature of QM presented by quantum information theory as the full truth!
Good point. I even mentioned it in one of my posts. But while continuous is nowhere differentiable. Still the paper I posted making the claim 'If one requires the transformation from the last axiom to be continuous, one separates quantum theory from the classical probabilistic one.' is not correct - it should include differentiability.
Thanks
Bill
This is too much required - wave functions need not be differentiable, only square integrable.
Yes (we won't go into Rigged Hilbert Spaces because it only makes it worse for my position) - but not nowhere differentiable because we have Schrödinger's Equation. I need to review the number of places I have seen it. But this it getting off-topic. I will need to look at the papers that state it first.
Thanks
Bill
Schrödinger's equation for ##N## particles and expectations ##\psi^*H\psi## make sense in the Soboloev space of once weakly differentiable functions on ##R^{3N}##. It contains the piecewise linear finite elements that could be used (in principle) to solve it numerically. I don't know whether this space contains nowhere differentiable functions but wouldn't be surprised.
bhobba said:
Yes [...] but not nowhere differentiable because we have Schrödinger's Equation.
Indeed, since ##3N>1##, the Soboloev space ##H^1(R^{3N})## contains nowhere differentiable functions. See the answer to my question Do Sobolev spaces contain nowhere differentiable functions? on MathOverflow.
This is a philosophical statement, not a scientific one, and certainly not a statement concerned with finding the complete pure mathematical theory for which QT is 'applied mathematics', i.e. the currently unknown uniquely correct mathematical model capable of capturing all of QT without any glaring conceptual problems.
From the history of physics, we have learned that all physical theories have such a unique form of pure mathematics underlying them: for Newtonian mechanics it is calculus, for Maxwell theory it is vector calculus, for GR it is Riemannian geometry, for Hamiltonian mechanics it is symplectic geometry, etc.; for QT we have not yet found the correct form of pure mathematics, this is still work in progress.
Having a unique mathematical theory underlying a physical theory - which moreover typically can easily directly be mathematically generalized (i.e. not merely heuristically e.g. through perturbative methods, linearizations or small angle idealizations) in a plethora of ways and directions - means that the physical theory can be derived from first principles and unified with other mathematical and/or physical theories; this means that there are no conceptual problems in the foundation of that physical theory.
All fundamental physical theories known so far were capable of being derived from first principles eventually, all except for QT, which moreover cannot easily be generalized or unified with other physical theories without extreme heuristics e.g. perturbation theory in the case of QFT.
The causal mechanism is not the preparation procedure; what you have offered is not an actual explanation but instead just a heuristic description of the phenomenology retrofitted into a post-hoc-ergo-propter-hoc statement; while such heuristics sound nice and help pragmatic experimentalists not to worry about the foundations, it is completely fallacious and therefore unacceptable for anyone really interested in rigourous explanation and understanding at an academic level.
Your heuristics import your philosophy into the practice of physics, because you are assuming that the axioms for QT that you have chosen are necessary, sufficient and capable of giving a complete conceptual description, while in actuality your chosen axioms are purely pragmatic heuristics; even worse when extended beyond their range of applicability they end up being patently fallacious and therefore fundamentally incapable of giving a complete description of the physics.
This is the danger of making a hurried premature axiomatization of a physical theory instead of finding the correct derivation from first principles i.e. constructing a new form of pure mathematics tailor-made for that physical theory which dovetails with the rest of pure mathematics: von Neumann et al. just bum-rushed a premature axiomatization of the physics into the foundation of QM and we are suffering to this day because of that.
The lesson to take away from this is that an axiomatization of a theory typically almost offers nothing of substance directly for the construction or discovery of new mathematics, especially if done sloppily/incorrectly because an axiomatization can easily so just end up being a meaningless game in formal mathematics; in other words axiomatization is an art form and not all axiomatizations are works of art, far from it.
Any physical theory which can not be based on a principle which is conceptually coherent by itself as a mathematical theory should always be looked at with the necessary cautionary suspicion; this is for me the same reason to be suspicious of string theory and also the same reason to be suspicious of the highly artificial mathematical constructions (i.e. non-pure) in mathematical economics and econometrics.
To demonstrate that your axiom-based heuristic view for QT without any coherent underlying principles - i.e. the minimal interpretation - is not a necessary way of looking at QT, others, in particular Popescu and Rohrlich have actually given a completely different way of changing the foundational structure of QT by changing the roles of axioms, postulates and principles: https://doi.org/10.1007/BF02058098
Psychologically problematic aspects of any explanation - especially a scientific explanation which can be put into mathematical form - implies conceptual problems within that explanation.
Conceptual problems in science practically always means that the particular chosen form of mathematics used in the explanation is not sufficient to fully describe the phenomenon that that form of mathematics is aiming to describe i.e. a more sophisticated form of mathematics is needed to naturally model/capture/explain that phenomenon.
I would say that it is pretty obvious that the problems in the foundations of QT are precisely of this nature: in the absence of glaring experimental deviations, we always needed a new form of mathematics to help solve the remaining conceptual issues and there is no reason whatsoever to suspect that the case is different for QT; on the contrary because of the unexplained introduction of complex numbers into the foundation of physics there is all the reason to suspect that a new form of mathematics is needed to resolve the problems in the foundations of QT.
For quantum mechanics, it is functional analysis in Hilbert spaces. Only for quantum field theory, clear mathematical foundations are fragmentary. The interpretation is a completely disjoint issue.
It is explicitly an assumption that the interpretation is a disjoint issue: all interpretative issues in physics always change when mathematical foundations change; the removal of Newtonian absolute space and time from the foundations of physics due to relativity theory is the prime example of this. Feynman spoke a lot about the resolution of such conceptual issues by changing foundations in The Character of Physical Law, among his many works and lectures.
Functional analysis in function spaces is only a necessary but not sufficient ingredient of the pure mathematical apparatus required to describe QT in full, exactly as you say.
Your arguments are also full of assumptions solely based on your faith, none of them verifiable.
But there is not the slightest hint that there is a deeper nice theory ''deforming'' quantum mechanics to something of which the latter is a limiting case. If it existed, it would have been found by now.
Alas, making assumptions is necessary in order to progress. Making assumptions in and of itself isn't problematic if one is aware that they are making assumptions; I am fully aware that I am doing this, not just reflectively but strategically: making your assumptions explicit directly opens them up to falsification. This is a formal reasoning strategy I learned in medical practice called diagnostics.
Not if the wrong conceptualization is missing; it of course only needs to be found once. Discovery of new pure mathematics in the absence of empirical guidance is not a trivial technical problem which can be resolved by throwing more money and man-power at it; if that was so all the Millenium Prizes in mathematics would have been solved ages ago.
It instead requires a careful solving of the conceptual issue in tandem with the construction of a novel mathematical concept; these events are exceedingly rare occurrences and they require creativity, imagination, vision and boldness beyond mere technical mastery taught in schools and upon which graduate students are selected for. Newton, Euler, Gauss and Grothendieck are prime examples of mathematicians who displayed all the required characteristics to achieve such things.
Since I don't care about psychology, which is far too complicated for me as a physicist, let me just pick this quote.
I don't know, what you mean by "first principles". For me what turned a posteriori after about 400 years of scientific research since Galilei and Newton to be something like "first principles" are symmetry principles, and a great deal of QT relies on these principles. I don't know, in which sense you mean that QT were not derivable from "first principles" in contradistinction to classical physics.
Derivation from first principles is a foundational research methodology used in theory construction which integrates the conceptual, the mathematical and the axiomatic based on an empirical fact. It can be done at multiple levels of completion; an example of a complete derivation from first principles would be inventing calculus, using it to define force and axiomatically defining space, time and mass all in tandem with each other in order to give a complete model of motion, an empirical phenomenon.
This is getting way off the topic of this thread. Please confine discussion to the thread topic.
Going back a bit in this thread...
I think I have learned a bit more about QFT from some of the great posts here. Especially learning some of the situations in which QFT would be helpful for application. Specifically, it seems as if QFT is best to apply when scattering is being discussed and the results might include any of a variety of particles. On the other hand: while QFT might include elements that describe entanglement, apparently that is a weaker/less useful side of things. My sense is that explains why entanglement experiments don't require the deeper theory of QFT - the basics of entanglement are well described by QM/QED without the need for any relativistic considerations (I don't consider descriptions of entangled photons as being relativistic although others might).
And as to some of the discussions about "microcausality": As I now understand it, there are 2 key (and somewhat opposing) elements at play. Both relate to the act of performing a measurement on entangled Alice and considering what happens to remote Bob (the previously entangled partner):
1) No signaling theorem being that the marginal probability of an outcome for Bob does NOT change due to Alice's choice of measurement. In short, Bob's outcomes are always random.
2) The experimentally demonstrated quantum nonlocality being that the state of Bob DOES change due to Alice's choice of measurement. In short, Bob is cast into a pure state relative to Alice.
I realize some of the posters here may not agree with my assessments, no problem there. But hopefully I am a little further along than before. :smile:
Again, as soon as photons are involved, there's no other way then QED to describe them adequately. QFT contains of course everything about entanglement as any flavor of QT.
Also read again you QFT books about what "local interaction" and "microcausality" means in contradistinction to long-ranged correlations due to entanglement. This resolves the apparent contradiction between the possibility of long-range correlations described by entanglement on the one hand and the fact that no instantaneous or even acausal influence of A's measurement on B's photons are necessary.
Yes.
I think a better phrasing would be that the correlations between Bob's and Alice's measurement outcomes can violate the Bell inequalities. Putting it in terms of "change of state" raises issues (discussed already quite thoroughly in some recent thread or other) that don't need to be raised to describe the experimental facts of quantum nonlocality.
Indeed, but the fact that your choice of measurement selects the sample space is what leads to the fact that the measurement "creates" in some sense the value. It means for example that we cannot think of the state ##|\uparrow_{z}\rangle## to actually represent a particle with angular momentum ##\frac{\hbar}{2}## about the ##z##-axis, for we must select the sample space via our measurement choice. It only means:
If you choose to measure ##S_{z}## then you will get ##\uparrow## with probability ##1##
Taking it otherwise, that is to actually mean the particle has ##\frac{\hbar}{2}## angular momentum about the ##z##-axis, leads to nonlocality issues.
It is in this sense that we are led to the measurement "creating the value". I don't think it is sloppy language.
vanhees71 said:
1. Again, as soon as photons are involved, there's no other way then QED to describe them adequately.
2. QFT contains of course everything about entanglement as any flavor of QT.
1. And yet, entanglement fundamentally does not require photons and does not require QFT. Hard to make that a case for a more complex theory. The old case of spin 1/2 electrons brings about the fundamental issues of quantum locality that we wish to resolve.
2. I guess I can't dispute that. But I certainly saw doubts about the entanglement side from a number of the posters. Apparently there are some entanglement issues that are not fully resolved. Although you seem satisfied, so that is a good recommendation.
