jimhebert
- 29
- 0
I have a pump that puts out 396 gal/hr of water. The output pipe on the pump is 9/16 inch in diameter. Is there a way to calculate the psi?
jimhebert said:I have a pump that puts out 396 gal/hr of water. The output pipe on the pump is 9/16 inch in diameter. Is there a way to calculate the psi?
On second thought, the piping is the same size as the outlet and it is only about 6 feet long, but the pump will be pumping the water up. It's for an aquarium.
jimhebert said:These specs may help in your calculations. The pump is a 3.5 horsepower.
The watts are 68, voltage =120, amps=.7
The Q max GPH = 687 gph
The Q min GPH = 449 gph
Head max =12.5 feet
jimhebert said:You mean it is not a 3.5 HP pump as the specifications say? According to your calculations, you believe it to be a 3 HP...Correct?
jimhebert said:In the calculator I entered q=687, and h=12.15 and shaft bph =3.52
jimhebert said:I bought this pump in pet shop and they had one in use in an aquarium. I do want to use it in a large tank. I would still like to know the approximate PSI output curve if possible.
The posted curve is not plotted correctly. The column with all the Syncras needs to be lifted up 2 increments and the H/m shifted to the right.
jimhebert said:I want to attach another device to the pump and it requires a certain psi to function properly.
