How Do I Calculate Torque for a Rotating Platform with a Stepper Motor?
  • Context: Undergrad
  • Thread starter Thread starter Art124
    Torque
This discussion focuses on calculating the torque required for a rotating platform powered by a stepper motor. The user has a moment of inertia of 2700 oz in² and needs to achieve an angular velocity of 0.2618 rad/s to rotate a 5 lb load. The calculated torque is approximately 15 foot-pounds, which is manageable for most stepper motors. A recommended resource for motor sizing is Oriental Motor's website.
  • Understanding of torque calculations for rotating systems
  • Familiarity with stepper motor specifications and performance
  • Knowledge of moment of inertia and its impact on rotational motion
  • Basic principles of angular velocity and acceleration
  • Research how to calculate torque using moment of inertia and angular velocity
  • Explore stepper motor specifications and selection criteria
  • Learn about the effects of load weight on torque requirements
  • Investigate the use of motor sizing tools, such as those provided by Oriental Motor
Engineers, hobbyists, and project developers working with stepper motors and rotating platforms who need to accurately calculate torque requirements for their applications.
Art124
Hello
I'm working on a project which requires a rotating platform.
I'm planning on turning the platform using a stepper motor,
however I'm sure how to calculate the torque required to move
the load.
Here is what I have:
the moment of inertial for the load and platform is: 2700 oz in2
the platform must turn 30 degrees in 2 seconds ( have a angular velocity of 0.2618 rad/s)
the motor is directly attached to the platform (no pulleys or gears)
I tried calculating the torque using the method in the pictures.
The torque I got seems too large to move a load which weights 5 lb. Perhaps I should have used the step angle, or maybe the formula I used does not apply to this problem.
Could someone help I would very much appropriate it. Thank you in advance.
Well what you have is roughly 15 foot-pounds of torque, which I believe most electrical motors should be easily capable of.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 16 ·
