How do I express an element in a matrix of s8 as a product of disjoint cycles?
  • Thread starter Thread starter beetle2
    Cycles Product
beetle2
Express the element in matrix
A=
1,2,3,4,5,6,7,8
4,1,3,2,8,5,6,7
of s8 as a product disjoint cycles
2. Homework Equations [/b
I pick a number say the first 1 and pu it in parenthises. (1,
I multiply by the number in th image so number 1x 4 which gives 4 so that does not equal my first number 1 so I add it to my list so we now have (1,4
I than go to the next column which is number 2 and multiply that by the image so 2 x 1 that equals 2 which does not equal 1 so I add that to my list so now its (1,4,2
Now the next column has 3 and 3 in the image so I disregard and close the parenthises
(1,4,2)
Is this right so far I'm not sure if I'm using the right process.
regards
Ok, it's possible we don't mean the same thing here. But here I think it goes... (and it has nothing to do with multiplying)
1,2,3,4,5,6,7,8
4,1,3,2,8,5,6,7
Take the first element in the list, that's 1. Add it: it gives (1 ...
The element under 1 is 4, add that to the list: (1 4 ...
The element under 4 is 2, add that to the list: (1 4 2 ...
The element under 2 is 1, we have that already in our list, so we close the paranthesis: (1 4 2)
Take the next element not in our list, that's 3: (1 4 2)(3 ...
The element under 3 is 3, we have that already in our list, so we close the paranthesis: (1 4 2)(3)
Take the next element not in our list, that's 5: (1 4 2)(3)(5 ...
The element under 5 is 8, add that to the list: (1 4 2)(3)(5 8 ...
The element under 8 is 7, add that to the list: (1 4 2)(3)(5 8 7 ...
The element under 7 is 6, add that to the list: (1 4 2)(3)(5 8 7 6 ...
The element under 6 is 5, we have that already in our list, so we close the paranthesis: (1 4 2)(3)(5 8 7 6)
We have exhausted all the elements, so this is the final answer.
I'm not sure. I checked then answers in the book and it has (142)(5876) not sure how they got it as theirs dosn't have a (3)?
Yes, both (142)(5876) as (142)(3)(5876) are correct. But it's a bit of a convention not to write the 1-cycles (like (3) ). So I guess (142)(5876) is the more standard solution. I should have mentioned that...
thankyou very much for the explanation micromass much appreciated
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
