How do I find the meaning of x in: 0,3x-6-x=-4,6 ? ;/
  • Thread starter Thread starter MathNub
To solve the equation 0.3x - 6 - x = -4.6, the first step is to simplify it correctly. The equation can be rewritten as 0.3x - 1x = 1.4 after adding 6 to both sides. This leads to -0.7x = 1.4, resulting in x = -2 when divided by -0.7. However, there is confusion regarding the calculations, particularly around the order of operations and the handling of coefficients. Properly applying these principles is crucial for arriving at the correct solution.
MathNub
Do you know how to solve linear equations?
0,3x-6-x=-4,6|+6
0,3x-x=1,4
-0,3x=1,4|:0,3
x=4,(6)
And I am lost now ;/ That number isn't right
MathNub said:
0,3x-6-x=-4,6|+6
0,3x-x=1,4
-0,3x=1,4|:0,3
This isn't right. 0,3x - x does not equal -0,3x. It may be easier to think of it as;
0,3x - 1x
(a variable without a coefficient really means that the coefficient is 1)
So what does this equal to?
-0,7x=1,4|:0,7
x=2
0,3*2-6-2=0,6-8=-7,4
But then we get the wrong answer.
MathNub said:
-0,7x=1,4|:0,7
x=2
No... :cry: the bold should be -0.7, not 0.7.
No... :cry: :cry: you need to follow the order of operations! Ignoring that we have the wrong answer for the moment, the multiplication comes first, then the 1st subtraction, and then the 2nd subtraction. You multiplied, and then did -6-2, which is wrong.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
