How do I find this? 60x10-6 = ?
  • Thread starter Thread starter Vancurt
The discussion focuses on understanding scientific notation, specifically how to interpret and convert values like 60x10^-6. Participants clarify that 60x10^-6 equals 60 divided by 1,000,000, and explain the significance of using powers of ten in measurements. The conversation also touches on the use of SI unit prefixes, such as "milli" and "giga," and the importance of knowing when to apply these notations. A key point raised is the confusion around when to use specific powers in scientific notation. Overall, the thread emphasizes the necessity of understanding these concepts for accurate scientific communication.
Vancurt
I don't understand where it comes from.
Say for example 60x10-6
or sixty times 10 to the power of mines six.
How do I find the last part?
1x10^-6 = 0.000001
10x10^-6 = 0.000010
60x10^-6 = _________
Does that help?
60x10-6 = 1 / (60x106)
106 = 10 * 10 * 10 * 10 * 10 * 10 = 1,000,000
10-6 = 1 / (10 * 10 * 10 * 10 * 10 * 10) = 1/1,000,000
Try..
1/(3-2) = ?
No. In fact, 60 × 10-6 = 60 / 106.
I know what it means but what I don't understand is where it comes from I mean like when do I know when to use it?
For example:
150mm dia
Elasticity 200gpaBut I wrote it down as 150x10^-3 and 200x10^9
I could of left it as 150 and 200 but I changed it to ^ instead, why did I do it and how did I know that it was ^-3 and ^9?
For example:
150mm dia
Elasticity 200gpa
The prefixes are part of the definition of the International System of units ("SI" units):
http://physics.nist.gov/cuu/Units/prefixes.html
And note that "Giga" (10^12) uses a capital "G", not a lowercase one as you have written. :smile:
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
