How do I know if my eigenvectors are right?
  • Thread starter Thread starter David Koufos
    Eigenvectors
The discussion revolves around verifying eigenvectors for a given matrix and understanding the implications of their correctness in relation to diagonalization. The subject area is linear algebra, specifically focusing on eigenvalues and eigenvectors.
  • Participants explore the relationship between eigenvectors and eigenvalues, questioning why their derived eigenvectors do not yield the expected diagonal matrix. They discuss the definition of eigenvectors and methods to verify their correctness.
Some participants have provided guidance on checking eigenvectors against the original matrix and eigenvalues. There is ongoing exploration of the implications of scalar multiples of eigenvectors and the conditions under which a matrix is diagonalizable.
Participants note that the diagonalization process may not hold in all cases, particularly when geometric and algebraic multiplicities differ. There is also mention of potential confusion regarding the correct formulation of matrix equations involving eigenvectors.
David Koufos
Given ##M = \begin{pmatrix}
2 & 2\\
2 & -1
\end{pmatrix}##, find the eigenvalues and eigenvectors and use them to find the matrix which gives the deformation relative to the new axes.
##CMC^{T} = D##,
C is the matrix whose columns are the unit eigenvectors derived from M,
D is a diagonal matrix which gives the deformation relative to the new axes,
Remember ##C^{T} = C^{-1}##, meaning C is orthogonal.
For
2 & 2\\
2 & -1
\end{pmatrix}##
I found the characteristic equation:
##( λ - 3 )( λ + 2)
\therefore λ = 3,-2##Going back we multiply
$$\begin{pmatrix}
2 - \lambda & 2\\
2 & -1 - \lambda
\end{pmatrix}\begin{pmatrix} x\\ y \end{pmatrix}$$
Which gives
\begin{matrix}
2x - \lambda x + 2y = 0\\
2x - y - \lambda y = 0
\end{matrix}
Now plugging in ##\lambda_{1}## and ##\lambda_{2}## we get
\begin{matrix}
-x_{1} + 2y_{1} = 0\\
2x_{1} - 4y_{1} = 0
\end{matrix}
\begin{matrix}
4x_{2} + 2y_{2} = 0\\
2x_{2} + y_{2} = 0
\end{matrix}
Using this system of equations I derived
##\left( 2, 1 \right )## & ##\left( -1, 2 \right )## for the eigenvectors. My question comes from this.
Moving on, the unit eigenvectors are
\begin{bmatrix}
\dfrac{2}{\sqrt{5}}& , \dfrac{1}{\sqrt{5}}
\end{bmatrix} and
\begin{bmatrix}
\dfrac{-1}{\sqrt{5}}& , \dfrac{2}{\sqrt{5}}
\end{bmatrix}The matrix C which is composed of the unit eigenvectors as columns is
$$C = \begin{pmatrix}
\dfrac{2}{\sqrt{5}} & \dfrac{-1}{\sqrt{5}}\\
\dfrac{1}{\sqrt{5}} & \dfrac{2}{\sqrt{5}}
\end{pmatrix}$$
and
$$C^{T} = \begin{pmatrix}
\dfrac{2}{\sqrt{5}} & \dfrac{1}{\sqrt{5}}\\
\dfrac{-1}{\sqrt{5}} & \dfrac{2}{\sqrt{5}}
\end{pmatrix}$$
But when I perform the multiplication I get
$$CMC^{T} = \begin{pmatrix}
\dfrac{-1}{5} & \dfrac{12}{5}\\
\dfrac{12}{5} & \dfrac{6}{5}
\end{pmatrix}$$ which is not a diagonal matrix.
I used maxima to compare answers and realize why my answer wasn't right. Maxima found for eigen vectors
##[ 2, 1 ] [ 1, -2]## whereas I have ##[ 2, 1] [ -1, 2]##.
When using the eigen vectors the computer found, I get
##CMC^{T} = \begin{pmatrix}
3 & 0\\
0 & -2
\end{pmatrix}## which is the solution I'm looking for.
My problem is that my eigen vectors satisfy the characteristic equation so why don't I get the same answer. For future problems how do I really know if my eigen vectors are right, or if they're off by a factor of -1?
Check them using the basic definition of the eigenvector and the associated eigenvalue. Check if the matrix times the eigenvector equals the eigenvalue times the eigenvector.
I just tried that with this specific example, and using my 2nd eigen vector ##(-1, 2)## I do indeed get that [M]u = λu. So now I'm just more puzzled. I don't understand why my eigen vector doesn't yield the desired diagonal matrix. I know that you can just assume the diagonalized matrix is just the eigen values along its diagonal and zeroes elsewhere, but my book says that's not true %100 of the time so I want to make sure I have the process right before I move on to higher dimensions.
Dear David,
I think what you said is correct. The diagonal matrices are matrices whose diagonal entries are the eigenvalues. This works in higher dimensions. I think when the book mentions it is not true 100% of the time, they probably mean that for some matrices
geometric multiplicity of λ ≠ algebraic multiplicity of λ
meaning these matrices are not diagonalizable.
Your eigenvectors are just multiples of their eigenvectors. If ##Mu=\lambda u## then clearly ##M(ru)=\lambda (ru)## for any real multiplier, ##r##. Likewise, if ##CMC^T = A##, then ##(rC)M(rC)^T = r^2A## for any real multiplier, ##r##. If one is a diagonal, the other one should also be a diagonal.
Try calculating ##C^{-1}MC##.
If the matrix is indeed diagonalizable, then it is 100% true that the diagonal elements of the diagonalized matrix are precisely the eigenvalues. Can you provide a verbatim quote of what your book is saying? Perhaps there is a subtlety that you are overlooking.
[2,1][1,−2] whereas I have [2,1][−1,2].
That's absolutely fine. Note that ##[1,-2]## is a scalar multiple of ##[-1,2]##. (The scalar is ##-1##.) In general, if ##v## is an eigenvector associated with a particular eigenvalue, then so is ##cv## for any nonzero scalar ##c##.
I think you need to simply interchange ##C## and ##C^T##.
Using Matlab, I find that if ##v_1 = \begin{bmatrix}2/\sqrt{5} \\ 1/\sqrt{5}\end{bmatrix}## and ##v_2 = \begin{bmatrix}-1/\sqrt{5} \\ 2/\sqrt{5}\end{bmatrix}##, and
$$C = \begin{bmatrix}v_1 & v_2\end{bmatrix} = \frac{1}{\sqrt{5}}\begin{bmatrix}2 & -1 \\ 1 & 2 \end{bmatrix}$$
then indeed
$$CDC^{T} =
\frac{1}{5}\begin{bmatrix}2 & -1 \\ 1 & 2 \end{bmatrix}
\begin{bmatrix}3 & 0 \\ 0 & -2 \end{bmatrix}
\begin{bmatrix}2 & 1 \\ -1 & 2 \end{bmatrix}
= \begin{bmatrix}2 & 2 \\ 2 & -1 \end{bmatrix} = M$$
Note that the eigenvalue-eigenvector equations are
$$Mv_1 = \lambda_1 v_1$$
and
$$Mv_2 = \lambda_2 v_2$$
If you combine these into a matrix equation with ##C = \begin{bmatrix}v_1 & v_2\end{bmatrix}##, then the result should be
$$MC = CD$$
or equivalently
$$C^TMC = D \text{ or }M = CDC^T$$
whereas you have written
$$CMC^T = D$$
which is incorrect.
Notice that ##C^TMC = \begin{pmatrix}3 & 0 \\ 0 & -2 \end{pmatrix}##.
Ok. I tried that and got the right diagonal matrix. Thank you. I mixed up ##CMC^{T}## with ##C^{T}MC##
then indeed
$$CDC^{T} =
and
$$MC = CD$$
or equivalently
$$CMC^T = D$$
which is incorrect.
Ok I found the diagonal now. Thank you. I mixed up ##CMC^{T}## with ##C^{T}MC##
then indeed
$$CDC^{T} =
and
$$MC = CD$$
or equivalently
$$CMC^T = D$$
which is incorrect.
  • · Replies 17 ·
