Can You Build a Flow Meter with Basic Electronic Components?
  • Thread starter Thread starter robertjrbobby
    Flow Meter
To build a flow meter using basic electronic components, a positive displacement design is recommended, where a piston or rotating shaft displaces a consistent volume of fluid per cycle. The key requirement is to measure the frequency of these cycles, which can be achieved using a magnetic pickup and notches on the shaft connected to an oscilloscope. This method allows for accurate flow measurement without complex electrical components. While simpler mechanical methods exist, utilizing electronic components aligns with the educational goals of an electrical engineering student. A focus on frequency counting will facilitate effective flow meter construction.
robertjrbobby
how do i make a flow meter, using whatever like resistors, capacitors, and make the flow meter go like 10 second per etc help need...i am in EE 2ll basic circuit engineerin? thanks
If you wanted to do this without the electrical stuff it's even easier. However, since you are an EE major that would defeat the purpose I guess.
The easiest thing I can think of is to make a positive displacement flowmeter. That means that for every cycle of the meter's motion (piston or shaft rotating) the same amount of fluid is displaced. The only thing that changes is the speed at which it operates. From your end, the only thing you have to have is something to count frequency. You can do that with a mag pick up and notches on a shaft hooked to an o-scope.
  • · Replies 56 ·
  • · Replies 22 ·
  • · Replies 17 ·
