How do I properly charge a VRLA battery?
2 replies · 3K views · last reply
pocho
hello, pozdrav
my question is about Valve Regulated Lead Acid battery. may i charge it only with "float" voltage (cca 2,25 Vpc) or do i have to "boost" it (2,4 Vpc) sometimes? if my battery gets discharged to 20% can i recharge it only with "float" voltage?
i have capacity cca 150Ah, 220V; temperature is ideal 20°
thank you
hvala
This a pretty good white-paper on batteries. It says VRLA batteries generally do better at the recommended float voltage, and don't require "equalization" like a flooded lead acid. But I would look at the manufacturer's documentation to be sure.
http://www.apcmedia.com/salestools/SADE-5TNRJR_R2_EN.pdf
thank you gtacs. this is a good resource. manufacturers documents are a bit confusing, i checked Sonnenschein and EnerSys websites.
it seems that "boost" treatment is not needed for VRLA. that is fine with me, because i had some trouble with overvoltages: boost_voltage x number_of_cells > voltage_tolerance.
thank you, have a nice day
