How High Did the Catapult Launch the Block on Mars?
  • Thread starter Thread starter pqnd1987
    Velocity
A group of workers on Mars built a catapult and launched a pyramid block with a density of 2400 kg/m³, which later crashed back into the catapult at a velocity of 20 m/s. The discussion revolves around calculating how high the block flew above the catapult, given Mars' gravity of 9.90 m/s² and assuming no air resistance. Participants emphasize that this is a homework question and direct the original poster to the appropriate forum for such inquiries. One user suggests using the velocity equation to determine the time of flight and distance traveled. The conversation highlights the importance of adhering to forum rules regarding homework questions.
pqnd1987
Hi I was wondering if anyone had any clue on this question
While sitting around waiting for interior decorators to finish up in the scroll repository, a bunch of bored and mischievous workers decided that they'd build a catapult. When they finally finished, it was able to shoot a projectile straight up into the air. So. in a move which they later regretted, they decided to launch one of the pyramid blocks, which had a density of 2400 kilograms per cubic meter.
When the block crashed back into the catapult, smashing it to pieces, it was determined to have a velocity of 20 meters per second. Assuming that gravity on Mars is exactly 9.90 meters per second squared, the block hit the catapult at the same elevation as it was launched from the catapult, and there was, miraculously, no air resistance acting on the block, how high, in centimeters, did the block fly above the catapult? Please round to the nearest centimeter.
First, please post homework questions in the appropriate (sub)forum, not in here.
Second, what are your ideas to get things moving?
Daniel.
This looks like a homework question. You somehow missed this notice
https://www.physicsforums.com/showthread.php?t=88596
Not a homework question. Looks like someone is trying to cheat at Lenny Conundrum.
In any case, they give you the acceleration. You need to first find the time it takes the object to fall by using the velocity equation. Then you can find the distance traveled. I won't do it for you because I want the points. :wink:
